There's an issue that affects RedHat distributions and might be the same case here.
Is there a programmed update to solve this?After Disabling SMB1 Support, Unable to Join AD Domain Via Winbind With "NT_STATUS_CONNECTION_RESET" Error
Solution In Progress - Updated an hour ago -
Environment
RHEL 5
RHEL 6
Winbind
Issue
After disabling the SMBv1 protocol on the Active Directory domain controllers, RHEL machines are unable to join via winbind. Enabling the SMB1 protocol again allows our RHEL 5 and 6 machines to join.
Resolution
There are no configuration changes that can be made to get Winbind on RHEL 5/6 to work with SMB1 disabled, so Red Hat recommends choosing between the following two paths:
- Recommended: Use SSSD to join to an Active Directory domain. See our guide: Authenticate RHEL manually to Active Directory with SSSD using AD backend
- Alternate: If using Winbind is a requirement, update the machine to RHEL 7, which supports the SMB2 protocol
Root Cause
The winbindd daemon in RHEL 5 and 6 is only able to communicate using the SMB1 protocol. This cannot be changed or improved.
The NAS is currently on 4.2.2 build 20161208. I'm going to try to update to latest 4.3.3 to see if it works...
