in my network i have two domain controllers with active directory service running. When i start "Quick Configuration Wizard" to join QNAP to domain, i have choice to select and add primary and secondary DC from the left side to right. Should i choose (add) only primary or both domain controllers?
[SOLVED] QNAP with primary and secondary domain controller in the network
Re: [SOLVED] QNAP with primary and secondary domain controller in the network
Of course, it is all explained in user manual. In 4.3.3. U have option of redundant domain controller, which is great.
Thanks again.
Thanks again.
