Hi everybody
Few firmware versions ago, not sure if it was 5.0.0.1858 or 1870, I upgraded one of our TES-1885 devices. Aside from questionable new interface look and somewhat sluggish work, NAS completely lost connection with AD. Wasn't able to perform any security operations with pre-existing AD connection and leaving/rejoining the domain could not be done (everything AD related worked just fine previously with fmw versions 4.x).
As AD connection is essential for us, I had to revert to latest v4.x firmware and disable auto-upgrade on all of our NASes.
I see that new firmware, 5.0.0.1932 build 20220129, is available for download. Can anybody confirm if this version works correctly with Active Directory authentication
Thanks in advance
Active Directory & firmware v5.x
Re: Active Directory & firmware v5.x
I use this latest build and LDAP sync works fine
Thanks dolbyman
