- Model name Ts-419 PII
- Firmware version and Build Number 4.2.0 201601119
- Operation System (OS) ARM
- OS Language ENg
- Number of HDDs 3
- HDD model 2 *WD Red 1.8gb, 1 seagate 1.8 st2000
- HDD capacity 2gb
- RAID configuration raid 5 3.58gb 62% used
- Services enabled, e.g. Download Station, DDNS, FTP, NFS file station photo music media lib web serverpptp ssh
- External devices, e.g. USB printer, e-SATA drive external USB Esata backup caddy
- NAS connection speed/ MTU igb 1500 mtu
Struggling to get to get Music station functioning properly even from pc on home network (never mind qmusic over the WEB which is my objective)
symptoms are that no songs are displaying but I do see album covers and artists
I cannot play any of these so I figure the media library is corrupt and needs rebuilding
my music is not in the multimedia path but in a standalone 'Music' Folder
music stored in this structure as flacs and mp3's
Music folder
Artist => Rolling Stones
Album => Sticky Fingers
So I go to Media Management advanced and try to add the folders I want
I am unable to add the folders or rather when I do they disappear after I save
I followed some forum advice to disable and rebuild etc but nothing
I do not want to nest everything under the QNAP Multimedia structure
So my question is how do I get my music folders into the multimedia library so they get indexed properly and appear in music station as songs that I can play
I have checked permissions and they all have at least 774 so minimum of read to anyuser
TWONKY sees and plays videos music just fine so its not permissions
I cannot be sure about this but I think these issues have only appeared since going to 4.2 as my library was fine before hand when I built it under 4.0
has something broken in media management or am I missing something
I see others have been having problems with this specific issue but no steps I can see have resolved it for me
can I go in via ssh and manually add the music folder as a last resort - Where??
Grateful for any advice
Cannot add folders to Media management
- Easy as a breeze
Re: Cannot add folders to Media management
if you can use SSH, try the following commands
/etc/init.d/mariadb.sh restart
/etc/init.d/QMediaService.sh restart
then try adding the folder again via the UI
worked well, able to add all my folders
interesting that even after several reboots this had not worked and needed the manual commands
Spoke to soon
The folders stuck in the UI for 30 seconds and went back in to add others, - nothing there
Under Multimedia management, media library tab it still thinks ive got thousands of music video and photo files (I assume from a previous indexing before upgrade to 4.2)
repeated manual stop and start as above but same problem.
- Easy as a breeze
you should file a ticket at https://helpdesk.qnap.com
something is definitely wrong with your media library
- Easy as a breeze
Same problem here!
Cannot add folder to media lib - tried restart and deactivate/reactivate, doesn't help.
See high CPU usage of mysqld
Is there a way to reset the media lib completely?
Same issue here. Does anybody have a solution?
- twinny
Same problem here. Can not add folder
Last night, I upgraded my TS-219P II from 4.2.0 (2016-01-01) to 4.2.2 (2016-12-14) and installed and enabled the "Media Streaming Addon".
This morning, I experienced exactly the same behaviour as described above: I was able to add "/Public/Music" as a media folder but within seconds, it disappeared from the list of folders.
However, after a reboot, I found that the folder was listed and the indexing was proceeding.
Perhaps this problem has been partially fixed by the most recent version of 4.2.2?
- OneCD
keithhanlan wrote:Perhaps this problem has been partially fixed by the most recent version of 4.2.2?
QTS changelog wrote: QTS4.2.0 Build 20160311
[Bug Fixes]
- Fixed an issue where users could not add shared folders as media folders in Multimedia Management.
Hallo, same Problem also with the newest update: 4.2.2 (2016/12/14)
The SSH trick worked!
OK, update:
The media-Server from Qnap is a crapp with large media collection (> 1TB)!
It is very slow and crashes everytime and then the media-folders disapear and it is not possible to add them again.
=> Solution: Twonky-MediaServer
@Qnap: if I can help with debugging of your Media-Server, let me know! At the Moment it is not a seriously MediaServer, sorry!!
I had similar problem, that I couldn't change any setting in Multimedia Management. I managed to solve the problem by disabling and enabling the DLNA media server. After disabling the DLNA just for a second, the settings of Multimedia Management were ok again, and I could add new media folders.
TS-231 with 4.2.2 (2016/12/14) firmware. My media library is something like 22000 files, ~350 GB.
- Been there, done that
+1
Same problem here!
Can´t add folders with movies!
Same problem here!
QTS 4.1.n/4.2.n/4.3.n/4.4.n MANUAL
Submit QNAP Support Ticket - QNAP Tutorials, Wiki - Product Support Status - Moogle's QNAP FAQ help V2 - QNAP Security Advisory
When you ask a question, please include the following:
Data md_checker nasreport (release 20180525)
Model: TVS-873e -- RAM: 20G -- FW: QTS 5.1.1.2491 build 20230815 (used as main storage + applications)
WD60EFRX-68L0BN1(x6) / WD80EFAX-68LHPN0(x1) Red HDDs -- RAID5: 8x6TB -- Cold spare: None
Model: TS-453B -- RAM: 8G -- FW: QTS 4.4.1.0978 build 20190626 -- BROKEN
Model: SS-839 -- SOLD after 12 years use! Never lost ANY data!
13 years of QNAP experience + Asustor and WD!
YES, that made it!johnson407 wrote:if you can use SSH, try the following commands
