Tunein Music station
Something wrong with Tunein in music station ?
TS-453 pro version 4.2.2 and music station 4.8.3
all the radio stations visible but no music playing , Always 3 bars next to song titles...
Re: Tunein Music station
same issue with me...
TS-453mini FW version 4.2.2 and music station 4.8.3
Same for me too!
TS-453 Pro + F/W 4.2.2 + Music Station 4.8.3
- Easy as a breeze
Hopefully the next version 5 for QTS 4.3 will be better. Music Station is painfully slow which is why I don't use it.
TS-212P QTS: 4.3.3.1864 build 20211212
2 x Seagate ST3000VN000 (RAID 1)
- razormoon
- Easy as a breeze
hmmm...i think I'll test this on the beta and see what I see.
- razormoon
- Easy as a breeze
I can confirm the same. It's not working...stream won't start. It works if I do it via HD Station app, though.
Using beta.
Using beta.
Any updates on this?
I have the same problem as the rest of you. I'm on a TS-251+ with QTS 4.2.2 and Music Station v4.8.3.
- razormoon
- Easy as a breeze
Open a trouble ticket. I had their attention and communication just halted.maxq10 wrote:Any updates on this?
I submitted a ticket for this back in October 2016. They asked me to record a video of the issue and my workaround to help them troubleshoot.
After following up several times, I got this reply on Dec 15 2016. Hopes this helps anyone waiting for the fix.
This issue is a bug, are RD team are in the process of getting this issue fix. You will have to wait until we release Music Station v. 5.0.2, this will include the fix.
Thank you,
In the mean time, I copied the command line that Tunein uses and pasted it to VLC and that worked fine under VLC.
If I remembered correctly, I had to save the radio station that I wanted to listen to as a favorite station.
Then go to the favorite radio station and right-click, then click on change settings.
That will display the command line along with the your Tunein license data.
I copied that command line to VLC and was able to listen to the desired station. It's a pain, but it works.
I have a TS-251A with QTS 4.2.3. I don't know if Music Station v. 5.0.2 will ever be available for this firmware OR if I have to upgrade to QTS 4.3.2 Beta to get Music Station v. 5.0.2 to be able to use TuneIn. Anyone knows what is the current version of Music Station on QTS 4.3.2 Beta?
Thank you,
- Easy as a breeze
I have 4.8.4 (see sig for build) and also get a "failed" when clicking on anything. MS is useless for me but when I first got the NAS, TuneIn did work but who wants to listen to the quality of most of the streams?cheaxiss wrote:I have a TS-251A with QTS 4.2.3. I don't know if Music Station v. 5.0.2 will ever be available for this firmware OR if I have to upgrade to QTS 4.3.2 Beta to get Music Station v. 5.0.2 to be able to use TuneIn. Anyone knows what is the current version of Music Station on QTS 4.3.2 Beta?
- fascik
Music Station 5.0.4. Beta QTS 4.3.3.0136 and still don't work When I clicked on radio in TuneIn nothing happend only Play button change to Pause.
March 2021 and Tunein still not working in Music station 5 (on TS-230) - Qnap WAKE UP!
- OneCD
