Hey guys
I have a Problem with my TS-451A regarding 5.1 Output in the HD Station. If I connect the QNAP to my A/V via HDMI, I only get Stereo Output instead of Dolby Digital 5.1.
I have Plex Home Theater on my Hybrid Desktop Station and only produces "Stereo" Output regarding to my A/V. I configured Plex for 5.1, according to the Output Settings.
If I connect my PS4 also via HDMI to my A/V System and play the same movies I did before, I get normal Dolby 5.1 Output.
Do I need to perform any Special Configuration on the QNAP itself?
Any help is much appreciated. Thanks
TS-451A HD Station only Stereo Output instead of 5.1
Re: TS-451A HD Station only Stereo Output instead of 5.1
I had similar issue using HybridDesktop Station. I switched to Linux station instead and discovered it was problem with Pulseaudio and had to do the following steps.
Qnap TS-453A/Linux Station 16.04
Problem: Pulseaudio only provides 2.0 or 2.1 PCM output to Audio Video Receiver and unable to enable passthrough audio in Kodi or VLC Media Player allowing DTS DD PCM
Fix: Prevent Pulseaudio from reloading after killing it and reload ALSA audio allowing to select proper HDMI device and enable passthrough audio in Kodi settings and VLC Media Player to send DTS 5.1, DD 5.1 or PCM 5.1 sound to Audio Video Receiver
Open terminal
## Change client.conf
sudo nano /etc/pulse/client.conf
## Change "; autospawn = yes" to "autospawn = no"
## Copy client.conf to ~/.config/pulse/
sudo cp /etc/pulse/client.conf ~/.config/pulse
## (optional) If Audio is a little bit crackling change default.pa
sudo /share/CACHEDEV1_DATA/.qpkg/ubuntu-hd/lxc/ubuntu_1604/pulse/pulse.common/default.pa
## Change "load-module module-udev-detect" to "load-module module-udev-detect tsched=0"
## Stop Pulseaudio
pulseaudio --kill
## reload ALSA
sudo alsa force-reload
Open terminal
## Stop Pulseaudio
pulseaudio --kill
## reload ALSA
I have the same issue using Plex Media Server. Do you know if the above procedure help with Plex too? Or, do I have to move to Kodi...? Thanks!
~ kalantan ~
- Trexx
Plex Home Theater is VERY old, update to PMP or OpenPHT. Default for both of them is Stereo output, and you have to make changes in the GUI's to let them know your receiver supports more channels.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
