Unable to acces music on QNAP NAS with Sonos system.
Dear all,
I am trying to add my music library to my sonos system and it is driving me nuts...
I tried everything i could find on this forum but i cant seem to manage it.
My NAS is connected with a LAN cable and is perfectly accesable from all other devices.
I have duplicated my music library on 3 folders to try different things:
1. Public folder
2. New folder called music, no password added. (guest acces R/w on)
3. Multimedia folder with the application music server installed.
On the SONOS app i go to preferences and add the folder on music Libr like this:
//192.(ipadres)/Multimedia
//192.(ipadres)/music
//192.(ipadres)/Public/music
I get an error message: Sonos cant add the folder, device refuses acces.
I have spend a couple of days pulling my hair out, cant get it to work, please help!
1. Public folder
- Trexx
Re: Unable to acces music on QNAP NAS with Sonos system.
What protocols does sonos support for remote access?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
CIFS/SMB.Trexx wrote:What protocols does sonos support for remote access?
Guest access R/W is a security liability and should never be used at all.Kaigeprod wrote:New folder called music, no password added. (guest acces R/w on)
With Sonos as with all other clients you should use a proper username/password to logon. The Sonos configuration prompts for that in the second step after supplying the UNC-name (\\ip_address\Shared_folder). What did you enter for username/password there?
Go check the System Connection logs on the Qnap (enable logging for SMB (Windows) first if not enabled) to get a clue on why Sonos isn't allowed to connect.I get an error message: Sonos cant add the folder, device refuses acces.
Likely issues:
- Incorrect username/password.
- Having deployed a Security level whitelist and not added all Sonos devices.
i created a new user called sonos and tested it again. still no succes, i looked at the log file. it did not make a log of the error connection so i tried to connect with qfinder pro and it did connect. i checked the security level, everything was fine here.
Finally i checked if the SMB was enabled. This was the problem, it was disabled. Sonos is now connected to the NAS!
Thanks guys!
@P3R i have another issue that you can find here: viewtopic.php?f=185&t=137716&p=648594#p648594
Any idea what this could be?
Thanks guys!
I have the same issue ! SONOS is not able to connect to the NAS multimedia folder.
How do you check if SMB is enabled ? on the NAS ? on the computer ?
twonky(DLNA) has a sonos mode .. maybe try the free trail (14days) and keep it if it works (20 bucks for a lifetime license)
On the NAS but incorrect user credentials or access rights to the media are probably more likely issues for most users.depomnica wrote:How do you check if SMB is enabled ? on the NAS ? on the computer ?
What Qnap model do you have?
What QTS firmware version and build is used?
What path are you adding to the music library settings in Sonos?
What username are you using in the Sonos?
Does the above username have access rights to the music files?
What type of music files do you have?
Argh! Again, again, again a trial. Why do we need to pay to get Sonos to work with QNAP NAS? I'm so ** off, so annoyed, this is a really serious non-sense. Yes, we can say it's not important, it's not a big deal, but thinking this way, nothing is important and then nothing makes sense anymore! I thought QTS was a kind of battery-included solution. You should not have to purchase additional software to make things work. Otherwise, just better off putting drives in a regular Linux PC and install needed software tools, and there are more free/open source software on Linux than on any proprietary platform.
I cannot find any way to add a SMB/CIFS share on the Sonos app, and even if I find it, typing UNC, user names and passwords with a phone is a real pain.
Eric it's on the NAS in settings not Sonos.EricBuist wrote: ↑Sun Dec 06, 2020 11:50 pmArgh! Again, again, again a trial. Why do we need to pay to get Sonos to work with QNAP NAS? I'm so ** off, so annoyed, this is a really serious non-sense. Yes, we can say it's not important, it's not a big deal, but thinking this way, nothing is important and then nothing makes sense anymore! I thought QTS was a kind of battery-included solution. You should not have to purchase additional software to make things work. Otherwise, just better off putting drives in a regular Linux PC and install needed software tools, and there are more free/open source software on Linux than on any proprietary platform.
Happy Owner of a TS-H973AX
4 off 4TB WD red spinners,
2 off 2TB WD Red SSD,
Cache 2 off WD 1TB Black U.2. Where there's a will there's a way!
You don't need to pay anything extra. The Twonky suggestion isn't required, it's a possible workaround if you can't get it to work the normal way.
I don't use Twonky and Sonos play my music from the Qnap with plain Microsoft networking all day long. You need to have Microsoft networking enabled in the Qnap and you need to allow SMB version 1 logins in the Qnap due to Sonos being an older client implementation.
In the Qnap admin interface, click Control Panel, Network & File Services, Win/Mac/NFS and make sure that Enable file service for Microsoft networking is enabled. Then click the Advanced Options button and make sure that SMB 1 is selected in the dropdown menu for Lowest SMB version. Close the Advanced Options popup window by clicking the Apply button and then click the Apply button again. I think this should all be configured this way by default, at least it was on a new Qnap I recently installed.
Neither of those are Qnap-issues.I cannot find any way to add a SMB/CIFS share on the Sonos app, and even if I find it, typing UNC, user names and passwords with a phone is a real pain.
I agree that writing long passwords on a phone is painful though so I add my shared folders using the Sonos app in a Windows computer because I find it easier. There I can copy paste in the UNC-name and long and complicated password, not having to type it for each shared folder I want to add to the Sonos.
I recommend that you create a dedicated user account on the Qnap for Sonos access that you only give access rights to your music but can be prevented to reach other things in the NAS. This will make it easy to differentiate the logins and improve security.
Be-aware that SMB1 is a security risk and it is being recommended that it is nor used.
Unfortunately, Sonos only seems to use SMB1 so if Qnap ever remove SMB1 the sonos will probably not work, but that is a Sonos not updating their stuff problem..
