is there a way to easily share a photo as an email attachment with a few clicks in Photo Station?
Qmail agent is installed including an email account.
After opening a photo > click on share > what next? I don't find an option for this.
How to share a photo as an email attachment from Photo Station?
- Moogle Stiltzkin
Re: How to share a photo as an email attachment from Photo Station?
go photostation, right click image, select share, choose email attachment.
for email sharing, i don't think setting up myqnapcloud is required? only if you do a direct link share which requires your myqnapcloud dyndns to be setup.
anyway yes left clicking (double click) opens pics. and the right click on images offers options... so you probably overlooked that is my guess pretty standard pc operation for files.
NAS
Network
Resources
Network
Resources
This way I get a share link in the email but not the photo itself as an attachment.
Is there a way to get the photo directly attached instead of a share link?
- Moogle Stiltzkin
yes you are correct.
i just tested it.
although there is a tab to share as link, i choose the email instead. yet it still shares a link... hm apparently one is to generate a link, and the other is to send the link by email also....
at this point i doubt it can do an attached image as you require. would be nice if they did
you could try inquiring helpdesk and ask them about it, also a feature request if it doesn't exist
https://helpdesk.qnap.com/
but for now.... you can ... browse to your email... then fill as usual. then select attachement file, browse to your QNAP, select the image to attach all you need for this is a browser to login to your email and being able to browse to your QNAP share (if you are remote, then you probably need vpn to access the QNAP. If you are on lan you can use shortcut, network, mapped drive to browse to the qnap)
NAS
Network
Resources
Network
Resources
Ticket raised with the following text:
Is there a way to easily share a photo as an email attachment with a few clicks in Photo Station?
I can only get a link but not the photo attached.
If this is not available please start a feature request for this. Good integration possibility of PhotoStation (or Qmagie) and QmailAgent. Quick win for the user, unique selling point in the NAS competetion
Any response to the ticket? Being able to send an email with photos as attachment seems a very basic feature.
- Don
Please open a new topic instead of posting to three year old threads.
