When I use the Multimedia Applications like QuMagie che Mysqld process take over 50% of CPU and the whole performance system goes down. Often during use the QuMagie I receive the timeout (the screenshot attached is timeout during the list of similar photos). This problem it's the same when I use the mobile app. During these actions there is only one user connected and no more requests requests are queued by other users or process.
My Qnap TS-251D is often in a stressed state when I use the mutimedia application because the Mysqld process use always at least 50% of CPU.
Do you have any ideas to help me?
Mysqld Hight CPU Usage when I use the Multimedia Application
Re: Mysqld Hight CPU Usage when I use the Multimedia Application
mysqld only running high, on qmagie usage ..or all the time ?
there has been known malware infections that use a compromised mysql server to mine crypto
is the nas exposed to the web ?
the Qnap is not exposed to the web and I access to it only by VPN. The Mysqld goes down to the CPU usage after 15/20 minutes that I don't use the Multimedia Applications.
Nobody use the Qnap only one user logs in.
I would open a ticket with qnap, glitches in the software are something we can do nothing about (user forum)
I have opened the ticket to the support. The support team after connected to my Qnap and seen the problem they saied that he will have to do escalation the problem to other support team.
Thanks dolbyman for your time.
- Diosd
Hi papas70,
did you get any response from the other support team? I have the same problem on my TS-431P:
PID USER STATUS RSS PPID %CPU %MEM COMMAND
7796 admin S 23M 1 37.5 2.3 mysqld
20413 admin S 4856 1 7.0 0.4 mysqld
29189 admin S 2472 1 5.6 0.2 myidbserver
Maybe their hints can help me also.
TS-431P 4xWDC-HDD 2.73 TB RAID 5
good news...The support by remote support did something because my problem has been resolved. I asked to the support what the second level of support was done but the answer was: I don't know.
The problem was resolved and I closed the ticket.
If you have the same problem my suggestion is to open a support ticket.
