QuMagie is not re-indexing new photos
Please post your questions about using the web-based Photo, Music, Video Stations here.
coupeborgward
Post by coupeborgward »
Hi there
I just noticed that new photos are not getting picked up my QuMagie. I guess the indexing might not get updated in real time which QuMagie is relying on.
Any settings I can change to get this working.
Using TS-251 with latest firmware
ukpbrown
Re: QuMagie is not re-indexing new photos
Post by ukpbrown »
It was the same for me. I added a load and nothing re-indexed.
It did however when I did a reboot. Obviously I am hoping that is not the answer
coupeborgward
yep I noticed the same this morning. I had to restart the qnap due to an update of the firmware. It started working after that. So not sure if the firmware update did the trick or the reboot :)
ukpbrown
Post by ukpbrown »
I'm not sure is the answer, to reboot every time you add some photo's :-) I was hoping for a live solution :-)
coupeborgward
just did a test after the firmware update. My qnap is now successfully indexing new photos without a reboot of the device. So all good for now
oliver.jennrich
First post
Post by oliver.jennrich »
I'm not sure that it has anything to do with the firmware - certainly QuMagie is not "volunteering" to indexing new photos after I added them. However, there is a (relatively) easy way to "encourage" the indexing:
1) log into your NAS via ssh
2) issue the command
/etc/init.d/QMediaService.sh restart
This is (more or less) what happens at a reboot.
john.w.zerbe
First post
Post by john.w.zerbe »
Mine wasn't indexing new photos and I stupidly used the "reindex" button and promptly lost all my face tags. I then found there was no way to restore them.
padrebardas
First post
Post by padrebardas »
john.w.zerbe wrote: Tue Jan 19, 2021 5:40 am Mine wasn't indexing new photos and I stupidly used the "reindex" button and promptly lost all my face tags. I then found there was no way to restore them.
The same thing happened to me today : QuMagie / Multimedia console was not indexing new photos added. I launched a re-indexing : tenths of hours of work lost.
That really is a show stoper for QNAP products
Theliel
Know my way around
Post by Theliel »
When this has ever happened to me, I have fixed it in two ways, usually always due to improper shutdown.
In the multimedia console, make sure 100% that the routes are added to QuMagie / QPhotos, since as I say after an incorrect shutdown they can disappear.
Once you are sure they are correct, reboot the NAS correctly.
hungchun
Post by hungchun »
Theliel wrote: Tue May 18, 2021 6:53 pm When this has ever happened to me, I have fixed it in two ways, usually always due to improper shutdown.
I have the same issue and it seems like just happened after a sudden power outage (several months ago...)
I reboot and it triggered check disk process (it takes several hours), and then the photo not update anymore.
I use qsync to sync my photos in .Qsync folder and set the .Qsync folder path in media console, when I open photo station and want to browse .Qsync folder, it pop a message says I don't have permission to do it...
I update QTS version to the latest (4.5.3.1697), photos still not auto updated.
I also tried re-indexing and lose all my photo tags...
don't know what to do, so sad.
awarberg
First post
Post by awarberg »
padrebardas wrote: Sat May 15, 2021 7:03 pm
I wish I had known this before I purchased my QNAP NAs. The software on the NAS itself is buggy, let alone the mobile apps (iPhone esp. is horrible).
steerage250
Getting the hang of things
Post by steerage250 »
I too, thought QuMagie was not re-indexing photos after ading another thousand to my collection. However, I notice that it is doing some every day - Multimedia Console (on the Overview page) will say "Completed" with today's date and a time around 5:30 am in the morning. If I then check under "People" in Photo Station, more face recognition has been done - not many, but some. It seems to be slowly getting there.
It would be nice to know what triggers it, and how to manually trigger it.
TS-251, PCs with Windows 10
steerage250
More thoughts: I have thumbnail generation scheduled to happen between 11pm and 5:30am each night. I suspect it is not a coincidence that the facial recognition stops at 5:30am. I wonder whether QuMagie is triggered as each new thumbnail is generated ?
Nickschnick
First post
Post by Nickschnick »
/etc/init.d/QMediaService.sh stop
/etc/init.d/QMediaService.sh start
works for me, does not reindex all photos, only the once added
Return to “Photo Station, Music Station, Video Station”
