Cannot delete Smart Playlist - Music Station 5, QTS 5.0.0.1828
After upgrading - I discovered no user can modify or delete smart playlist. I suspect it has to do with new Database used in QTS 5.0.0.1828 but could be anything - anyone else run into this and have a solution?
Re: Cannot delete Smart Playlist - Music Station 5, QTS 5.0.0.1828
Did you disable the "admin" user as recommended by the newer firmwares?
If a playlist was created by the admin user then it may not be possible to edit it after that account is disabled. Assuming you don't have lots of playlists, the easiest fix is to re-enable the admin user, delete the playlist and recreate it as a different user and when all are done disable the admin account again.
