My TS-253D is connected via HDMI to the TV.
Does anyone out there have a problem with HD Player NOT loading?? HD Player worked, that is until the latest update was installed.
All the recommended software has been installed, Photo, Music, Video stations. MultiMedia Console is installed and set to the source folders.
Video Station has been set to the source folders.
When opening HD Player all I get is a BLANK screen or the message "LOADING DATA - PLEASE WAIT". After a few minutes the screen reverts back to the menu.
I have reported the problem to the HELP Desk but they don't have a solution, yet. I suspect HD Player is NOT "parsing" to Video Station.
Any suggestion would be appreciated.
HD Player NOT Loading
- Muphin
Re: HD Player NOT Loading
I thought HDMI connections from the NAS are the best thing since sliced bread ?
viewtopic.php?f=21&t=167840&p=830884#p830884
Seems your hot tip "use the NAS as a player" might not be that great
Anyways, If QNAP is already on the case your probably have the best suitable on there already.
