No permission to upload photo in PhotoStation
I am an admin user, after updated to QTS 4.02, when I try to upload photos to Photostation (from remote location) I got these message "Sorry, you do not have permission to import files.", anyone know what is the problem? Thanks!
Re: No permission to upload photo in PhotoStation
Same issue with non-Admin User. FS permission are ok. Upload with Filestation is working.
Is there any option to configure upload oppertunity on user level?
Thanks in advanced
Thanks in advanced
- pwilson
pat2097 wrote:I am an admin user, after updated to QTS 4.02, when I try to upload photos to Photostation (from remote location) I got these message "Sorry, you do not have permission to import files.", anyone know what is the problem? Thanks!
- Heartbleed vulnerable Firmware installed! Upgrade Firmware to at least QTS v4.0.7 immediately!!!!!!!!
- What is the full path to your Photo store? (/share/Multimedia/photos perhaps?)
- What is your Windows username?
- Do you have a user with identical username/password setup on the NAS?
- Which Operating System is installed on the PC you use to access your NAS?
- Have you enabled the Home Folders feature on the NAS?
- What version of Photo Station is installed?
Patrick M. Wilson
Victoria, BC Canada
QTS v4.1.0 is installed
/share/MD0_DATA/TCA , for this non-Admin user I created own home-dir which is visible in photo station
windows 8.1
not sure , how I can enable home folder feature?
PhotoStation 4.1
windows 8.1
PhotoStation 4.1
- pwilson
Install PuTTY on your Windows PC, and use it to login to your NAS via SSH as "admin"manwecke wrote:QTS v4.1.0 is installed
windows 8.1
PhotoStation 4.1
Run the following command:
getfacl /share/MD0_DATA/TCA
You'll find information on the Home Folders feature in the Home Folders section of the fine manual.
Patrick M. Wilson
Victoria, BC Canada
Output from getfacl /share/MD0_DATA/TCA
getfacl: Removing leading '/' from absolute path names
# file: share/MD0_DATA/TCA
# owner: TCA
# group: administrators
user::rwx
group::rwx
other::rwx
# owner: TCA
user::rwx
group::rwx
other::rwx
- pwilson
No ACL's enabled. No wonder you are having issues.manwecke wrote:Output from getfacl /share/MD0_DATA/TCA
# owner: TCA
user::rwx
group::rwx
other::rwx
Still no answers to my previous questions.....
Patrick M. Wilson
Victoria, BC Canada
I tried to answer your previous questions already
version QTS v4.1.0 is installed
windows 8.1
PhotoStation 4.1
windows 8.1
PhotoStation 4.1
- pwilson
Back to SSH....manwecke wrote:I tried to answer your previous questions already
windows 8.1
PhotoStation 4.1
testparm -s -l --section-name=TCA 2>/dev/null
Patrick M. Wilson
Victoria, BC Canada
- doktornotor
Noone reads the manuals? Doing things properly has the wonderful advantage that there's no need to create anything manually, plus the correct permissions are set up for the home folders of each user.manwecke wrote:not sure , how I can enable home folder feature?
Home Folders
Enable Home Folders to create a personal folder to each local and domain user on the NAS. Users can access their folders "home" via Microsoft networking, FTP, AFP, and File Station. All the home folders are located in the shared folder "Homes", which can only be accessed by "admin" by default.
To use this feature, click "Home Folders". Select "Enable home folder for all users" and the disk volume where the home folders will be created in. Click "Apply".
I'm gone from this forum till QNAP stop wasting volunteers' time. Get help from QNAP helpdesk instead.
Warning: offensive signature and materials damaging QNAP reputation follow:
QNAP's FW security issues
QNAP's hardware compatibility list madness
QNAP's new logo competition
Dear QNAP, kindly fire your clueless incompetent forum "admin" And while at it, don't forget the webmaster!
Any news? I have qPhoto lite on my iPhone, QNAP TS-210 with 4.1 but every time I try to upload a photo it says "Sorry, you don't have permission to upload photos. Please administrator for more information". Given the fact that I am the administrator, I contacted myself but I did not give myself an answer ( ).
To make sure I am not wasting anyone's time I will recap that I have open a all access to everyone for everything, All users have access to Home folder, but, still always the same message.
Any suggestion? I tried with Admin user, and at least additional two user ID. with Qfile I can do anything I want with the same user and same permissions..
Thanks in advance
/ftp
Thanks in advance
/ftp
I'm having this same problem but using Android QPhoto. I too have checked folder permissions and I have R/W access to everything, including home folders. I am using QTS v4.1.1 on TS-219P+.I try to upload a photo it says "Sorry, you don't have permission to upload photos. Please administrator for more information"
Paths added to Multimedia manager are /Qmultimedia/ and /homes
Suggestions anyone?
any resolution for this issue?
It is an old thread. but I had the same issue.
What happened? during the installation of my nas there was a problem with the raid set. so I removed the first volume and re-created. so alle the default folders where gone.
after I restored this folders there was still an issue with photostation.
go to the appcenter and remove photostation and install it again.
After this everything was working.
