Hi.
Just two questions :
1) It seems that it's not possible to upload more than one photo at a time in the station (or i didn't find how to do so), is there a way to upload a full directory ?
2) The interface is in english, are there any translations available ?
Uploading photos and translation
- Cameron
QNAP TS 209 Pro II - Version 3.2.0 build 0622T
2x1To Seagate ST31000340AS SD1A - RAID 1
FTPES enabled
FTPES enabled
Re: Uploading photos and translation
1) If using Lan connection, you can directly copy the photos into the folder or sub-folders of "Qmultimedia"; If using Wan connection, you need to use some FTP clients(eg. FileZilla) to connect the server and then upload the photos to "Qmultimedia"
2) You can select the language in the "Turbo Station" page. If you select france and then click "Multimedia station", the pages will come out with france descriptions
- Cameron
It works, thanksSKwan wrote:1) If using Lan connection, you can directly copy the photos into the folder or sub-folders of "Qmultimedia"; If using Wan connection, you need to use some FTP clients(eg. FileZilla) to connect the server and then upload the photos to "Qmultimedia"
Doesn't seem to work for other users from internet, that's in english ...SKwan wrote: 2) You can select the language in the "Turbo Station" page. If you select france and then click "Multimedia station", the pages will come out with france descriptions
Do I really need to show the "Turbo Station" page to translate it ?
FTPES enabled
FTPES enabled
Can you access below page and select the language?
- Cameron
Yes i can.
But if i give the adresse of the multimedia station (http://.../Qmultimedia/cgi-bin/index.cgi), the translation is not available for there.
I mean if the administration interface is in the french, all other interfaces should be in french (no need to tranlate it why the admin panel).
I think that would be a cool feature
FTPES enabled
FTPES enabled
