Problems with RTTR after Firmware Upgrade
Discussion on remote replication.
ediazecg
Post by ediazecg »
I have two QNAP TS-869U-RP have been using RTTR for over a year with no problems! Yesterday I decided to upgrade my destination QNAP, with no problems RTRR was running great, later at night decided to upgrade the Source, after that all of the jobs fail in differentes moments, sometimes they say that are in "Standby" moments later I see "Retry2, will restry afet xx seconds".
When I look at the logs I see this:
[RTRR Job] (Sync) Job XXXXXXr-->Remote:XXXXXXX failed: Server is terminated by a request!Please check Network Access Protection in server setting page, or Incoming List page.. Begin the 1st retry.
But I don't have anything set, and it was working fine before the upgrade. The firmware I am using is "4.2.0 2015/09/25". Anyone with the same error?
Edit 1: I forgot to mention the only real change I did was to the source I now have Port Trunking with Balance-RR.
paolomarino
Easy as a breeze
Re: Problems with RTTR after Firmware Upgrade
Post by paolomarino »
i have the same problem.
when i have upgraded my source nas to 4.2.0 build 820 the rtrr have stopped working with the same error.
have u solved ?
Happy Qnap TS-509 Ultra (Intel E7500 + 2GB RAM + 20TB WD RED) Owner :)
Happy Qnap TS-870 Ultra (Intel I7-3770T + 16GB RAM + 64TB WD RED) Owner :)
poidogpon2
Post by poidogpon2 »
Unfortunately I am having the same issue. Upgraded the TS-221 to Version 4.2.0 (2015/09/25) this morning and started getting flooded with RTRR errors. I made no other changes. The remote TS-451 was upgraded a few weeks ago without issue. The strange thing is, it still seems to replicate my files, but generate the errors. I've tested a couple folders by placing a small test file into them, waiting a minute, then looking at the remote folder, and it contains the file. Hopefully someone can explain whats going on. I don't want to spend my weekend on this!
[2015/10/09 08:10:05] Enter the real-time syncing phase.
[2015/10/09 08:24:46] Server is terminated by a request!Please check Network Access Protection in server setting page, or Incoming List page. Begin the 1st retry.
[2015/10/09 08:25:47] Synchronize files from local folders to remote folders.
paolomarino
Easy as a breeze
same situation and same error:
here my log:
[09-10-2015 02:50:02] Job [1 - Sinc] started.
[09-10-2015 02:50:05] Synchronize files from local folders to remote folders.
[09-10-2015 02:50:05] Server IP address: 192.168.1.82, port number 8899.
[09-10-2015 02:50:05] The SSL connection option is disabled.
[09-10-2015 02:50:05] The ZIP-compression option is disabled.
[09-10-2015 02:50:05] The number of folder pairs = 1.
[09-10-2015 02:50:05] Pair1 = [Multimedia/Video/Video-Vari, Qmultimedia/Video/Video-Vari].
[09-10-2015 02:50:05] Schedule type: Daily (hour = 2, minute = 30).
[09-10-2015 02:50:05] The deleting extra files option is enabled.
[09-10-2015 02:50:05] The checking data content option is disabled.
[09-10-2015 02:50:05] The detecting sparse files option is disabled.
[09-10-2015 02:50:05] The extended attributes option is disabled.
[09-10-2015 02:50:05] Symbolic link files are included.
[09-10-2015 02:50:05] The detail log is enabled with the maximum size 100 MB.
[09-10-2015 02:50:05] Maximum retry times: 3; Retry interval in seconds: 60; Connection timeout in seconds: 120; Current retry number: 0.
[09-10-2015 02:50:05] Other denying files(case-insensitive): .DS_Store, .Thumbs.db, /@Recycle, /.@__thumb.
[09-10-2015 02:50:25] Server is terminated by a request!Please check Network Access Protection in server setting page, or Incoming List page. Begin the 1st retry.
i have opened a topic here: http://forum.qnap.com/viewtopic.php?f=15&t=115042
i have opened even a ticket to qnap
waiting an answer
ediazecg
Post by ediazecg »
UPDATE: Still having Problems the workarround I found instead of Real-Time I set some of them to Schedule and it seems to work with a few ones.
BeerWill
First post
Post by BeerWill »
In case anyone else comes across this, I had this same problem today after updating to 4.2.0 ("Server is terminated by a request!..."), and solved it by re-creating the replication jobs with exactly the same settings and the new versions then worked fine.
Will.
alios
Post by alios »
still doesn`t work, even after i removed the jobs and set them up again
need backups ? i got tons
QNAP fan and supporter... running only qnap hardware:
TS-459 Pro2
TS-415
TS-431P2
TS-451A
Return to “Remote Replication/ Disaster Recovery”
