Hello all,
After upgrading QTS from 4.2.xxx to 4.3.2.0026, RTRR using FTP over SSL/TLS was not working anymore ! (sync remote folder with local one)
When I test my configuration by pushing "Test", the bandwidth is around 225 octets/sec (it was 15Mb/s before the upgrade).
I tried to reconfigure my jobs and noticed that I could not set the remote directory to more than the the first directory starting from root (/folder/). I can't reach the subfolders.
I opened a ticket a week ago. I am still waiting an answer.
Do anyone faced the same issue ?
Any idea about how to fix this ?
Thank you for your help.
RTRR FTP SSL/TLS Explicit not working after upgrade to QTS 4.3.2
Re: RTRR FTP SSL/TLS Explicit not working after upgrade to QTS 4.3.2
Can anyone please try this under QTS 4.3.2.0026 and confirm that issue ?
Any suggestions about how to fix this ? Any workaround ?
I just upgraded QTS to 4.3.2.0050, the problem is still there !
The support told me that many issues will be fixed in the new beta (I guess they were talking about this one), but I see that the problem is still there.
They said that FTP(s) issues will be fixed. I guess I will need to wait a little more.
If someone can try an RTRR with FTP over SSL and confirm this will help.
Hello
I am facing the same issue on TS-451+ running version 4.3.3.0210 released on 2017/06/06. Bug still there....
Any support please?
Any support please?
Not exactly the same problem but..
I am running on a TS-219P II firmware 4.3.3.0404 and with HybridBackup version 2.1.171130
When I try to create a sync job to FTP, I can't see destination folder not even root.
In an earlier version, can't remember whiche one, it was working okay.
If I create a cloud job, i can see destination folders.
