Hey all,
We have been using QNAP TS453 Pro ( 4Bay - 4 x 6TB) to backup our file server data.
Now we want to setup Offiste backup of this File Server data as a part of Disaster Recovery Plan. And we are about to get QNAP TS453A (4Bay - 4 x 6TB) to place in Offsite location.
So I just wanted to know the best practice to do it. After googling I understand we need to use Remote Replication option to replicate the data from NAS 1 (Onsite) to NAS 2(Offsite).
And I am afraid if it's not real backup, because it's going to just maintain a as it is copy on Offsite, and what if, onsite data gets virus infected or corrupted, so Remote replication will copy the infected/corrupted data, so no use of offsite, in this case, only the scenario it will work is, server crashed and onsite backup fails, then offsite will work.
Please correct me if I am wrong.
Appreciate you responses !!
Offsite Backup with QNAP NAS boxes TS453 Pro and TS453A
Re: Offsite Backup with QNAP NAS boxes TS453 Pro and TS453A
Use the Backup versioning app (in beta but have worked reliably a long time for me) in Backup Station/RTRR.apgnas wrote:...what if, onsite data gets virus infected or corrupted, so Remote replication will copy the infected/corrupted data...
Okay, I will test it.P3R wrote:Use the Backup versioning app (in beta but have worked reliably a long time for me) in Backup Station/RTRR.apgnas wrote:...what if, onsite data gets virus infected or corrupted, so Remote replication will copy the infected/corrupted data...
Thanks.
How about DDNS options provided on QNAP ?
dyn.com
update.ods.org
members.dhs.org
dyns.cx
3322.org
noip.com
selfhost.de
oray.com
Whether any one of them are free to use ? without annoying things ? For example noip.com is free but every 30 days you need to refresh the account by logging in etc. otherwise, ddns will not work. So which one is better one ?
Also I found freedns.afraid.org which is totally free without annoying but there is no option on QNAP, is there any to use it ?
Thanks !!
dyn.com
update.ods.org
members.dhs.org
dyns.cx
3322.org
noip.com
selfhost.de
oray.com
Thanks !!
DDNS and VPN should be implemented in the router/firewall doing the NATing.
Having those on an inside host, like the NAS, is an ugly hack. Avoid as long as possible.
I use https://freedns.afraid.org/, have worked great for me.
Trying to setup offsite at Home. VPN is not supported by Router.P3R wrote:DDNS and VPN should be implemented in the router/firewall doing the NATing.
For DDNS, I am not seeing free other than Freedns.afraid.org. I think I cannot use this on QNAP, as it's not included there, right ?
And also, on my router, its not included (freedns.afraid.org), so what options do I have ?
I can understand not to included DDNS on NAS itself, I will try to avoid.
Then why not get a better router/firewall?apgnas wrote:Trying to setup offsite at Home. VPN is not supported by Router.
I wouldn't know, never tried. I've only used it on routers (dd-wrt) and firewalls (pfSense).For DDNS, I am not seeing free other than Freedns.afraid.org. I think I cannot use this on QNAP, as it's not included there, right ?
In your opening post you asked for the best practise. Using RTRR over a secure connection (VPN when across internet) is best practise.
