TS-853A, QTS 4.3.3 Build 20170516
I've created RTTR replication. During running I get an error:
Any suggestions?
[2017/06/12 21:53:16] Job [Remote:DL-->DL] started.
[2017/06/12 21:53:16] Synchronize files from remote folders to a local folders.
[2017/06/12 21:53:16] Server IP address: vesolje, port number 8899.
[2017/06/12 21:53:16] The SSL connection option is disabled.
[2017/06/12 21:53:16] The ZIP-compression option is disabled.
[2017/06/12 21:53:16] The number of folder pairs = 2.
[2017/06/12 21:53:16] Pair1 = [DATA/DL, DL].
[2017/06/12 21:53:16] Pair2 = [DATA/SZ, SZ].
[2017/06/12 21:53:16] Schedule type: Manually.
[2017/06/12 21:53:16] The deleting extra files option is disabled.
[2017/06/12 21:53:16] The checking data content option is disabled.
[2017/06/12 21:53:16] The detecting sparse files option is disabled.
[2017/06/12 21:53:16] The extended attributes option is disabled.
[2017/06/12 21:53:16] Symbolic link files are included.
[2017/06/12 21:53:16] The detail log is enabled with the maximum size 10 MB.
[2017/06/12 21:53:16] Maximum retry times: 3; Retry interval in seconds: 60; Connection timeout in seconds: 120; Current retry number: 0.
[2017/06/12 21:55:17] # ERROR: Can't create the "DATA/DL/prtg.zip" file! (-62)
[2017/06/12 21:57:17] The synchronization stopped with errors.
[2017/06/12 21:57:17] Sync statistic: Total number of the folders: 2. Total number of the files: 0. Total updated size: 69.00 MB. Average updating speed: N/A. Time elapsed: 4 minutes 1 second
[2017/06/12 21:57:24] Connection timed out, bad networking quality or the server connection closed unexpectedly! Begin the 1st retry.
[2017/06/12 21:58:24] Synchronize files from remote folders to a local folders.
[2017/06/12 21:58:24] Server IP address: vesolje, port number 8899.
[2017/06/12 21:58:24] The SSL connection option is disabled.
[2017/06/12 21:58:24] The ZIP-compression option is disabled.
[2017/06/12 21:58:24] The number of folder pairs = 2.
[2017/06/12 21:58:24] Pair1 = [DATA/DL, DL].
[2017/06/12 21:58:24] Pair2 = [DATA/SZ, SZ].
[2017/06/12 21:58:24] Schedule type: Manually.
[2017/06/12 21:58:24] The deleting extra files option is disabled.
[2017/06/12 21:58:24] The checking data content option is disabled.
[2017/06/12 21:58:24] The detecting sparse files option is disabled.
[2017/06/12 21:58:24] The extended attributes option is disabled.
[2017/06/12 21:58:24] Symbolic link files are included.
[2017/06/12 21:58:24] The detail log is enabled with the maximum size 10 MB.
[2017/06/12 21:58:24] Maximum retry times: 3; Retry interval in seconds: 60; Connection timeout in seconds: 120; Current retry number: 1.
RTTR: Broken pipe, the server connection closed unexpectedly!.
Re: RTTR: Broken pipe, the server connection closed unexpectedly!.
next execution ended with different error (-32).
Simon
[2017/06/13 09:21:45] Job [Remote:DL-->DL] started.
[2017/06/13 09:21:45] Synchronize files from remote folders to a local folders.
[2017/06/13 09:21:45] Server IP address: vesolje, port number 8899.
[2017/06/13 09:21:45] The SSL connection option is disabled.
[2017/06/13 09:21:45] The ZIP-compression option is disabled.
[2017/06/13 09:21:45] The number of folder pairs = 2.
[2017/06/13 09:21:45] Pair1 = [DATA/DL, DL].
[2017/06/13 09:21:45] Pair2 = [DATA/SZ, SZ].
[2017/06/13 09:21:45] Schedule type: Manually.
[2017/06/13 09:21:45] The deleting extra files option is disabled.
[2017/06/13 09:21:45] The checking data content option is disabled.
[2017/06/13 09:21:45] The detecting sparse files option is disabled.
[2017/06/13 09:21:45] The extended attributes option is disabled.
[2017/06/13 09:21:45] Symbolic link files are included.
[2017/06/13 09:21:45] The detail log is enabled with the maximum size 10 MB.
[2017/06/13 09:21:45] Maximum retry times: 3; Retry interval in seconds: 60; Connection timeout in seconds: 120; Current retry number: 0.
[2017/06/13 09:21:46] # ERROR: Can't create the "DATA/DL/prtg.zip" file! (-32)
[2017/06/13 09:21:46] The synchronization stopped with errors.
[2017/06/13 09:21:46] Sync statistic: Total number of the folders: 2. Total number of the files: 0. Total updated size: 60.00 MB. Average updating speed: N/A. Time elapsed: 1 second
[2017/06/13 09:21:55] Broken pipe, the server connection closed unexpectedly! Begin the 1st retry.
[2017/06/13 09:22:55] Synchronize files from remote folders to a local folders.
[2017/06/13 09:22:55] Server IP address: vesolje, port number 8899.
[2017/06/13 09:22:55] The SSL connection option is disabled.
[2017/06/13 09:22:55] The ZIP-compression option is disabled.
[2017/06/13 09:22:55] The number of folder pairs = 2.
[2017/06/13 09:22:55] Pair1 = [DATA/DL, DL].
[2017/06/13 09:22:55] Pair2 = [DATA/SZ, SZ].
[2017/06/13 09:22:55] Schedule type: Manually.
[2017/06/13 09:22:55] The deleting extra files option is disabled.
[2017/06/13 09:22:55] The checking data content option is disabled.
[2017/06/13 09:22:55] The detecting sparse files option is disabled.
[2017/06/13 09:22:55] The extended attributes option is disabled.
[2017/06/13 09:22:55] Symbolic link files are included.
[2017/06/13 09:22:55] The detail log is enabled with the maximum size 10 MB.
[2017/06/13 09:22:55] Maximum retry times: 3; Retry interval in seconds: 60; Connection timeout in seconds: 120; Current retry number: 1.
Simon
