Looking for a solution for daily incremental backup.
Hello guys,
I'm newbie with QNAP, so it might be a stupid question.
I am looking for a software/utility to install on workstations (Windows) which use incremental backup on QNAP NAS ( TS-EC1280U ).
I want a daily file backup, to keep at least 7 versions of the files, but the backup must be incremental, to save storage space and time.
Now, I''m using NetBack replicator, but not performs incremental backup and can't set the maximum number of versions.
I also tried to use AOMEI Backupper, it does incremental backup, but supports versioning only on PRO version.
So if there is some app on QNAP which supports incremental backup & versioning, with windows client, I think this is the best option. I also worked before with another NAS, and there was some apps like this.
Or can someone tell me a free solution to do this kind of backup?:)
Thank you!
Thank you!
- Toxic17
Re: Looking for a solution for daily incremental backup.
What type of data are you wanting to backup this much? why not keep the data on the NAS and then do backups of that data using Hybrid Backup Sync (with versioning) to you external backup.
Please dont say your NAS(unknown - brand, model, firmware) is your backup solution....it requires to be backed up to...
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
Thanks for reply.
I want to backup important Files.
And yes, I want to use the NAS ( QNAP TS-EC1280U, Firmware: 4.3.3.0238 Build 20170703 ) as a solution for this files.
I have configured two volumes ( one with Raid 10 for ISCSI and Raid1 for backup).
So, there's no free software for this kind of thing? To do incremental backup, daily, with number of versions, maybe email notification and so on?
all that would be 3rd party software...read through the myriad of offerings
also .. why raid10 ?
For safety and speed?
4x WD Gold 4TB Datacenter + 1 Hot Spare.
I'm using raid10 for iscsi & virtualization.
I don't really know why you are asking me this question.. Do you have a better option?
Regarding the software that I'm looking for, I was hoping I'll find it here.
RAID10 has no significant befits over RAID6 ... and has less redundancy
Even the PRO users with 10GbE and 4K NLVE rigs stopped using RAID10 .. so just as a hint.
Regarding the software, the NAS would be a storage target for that software of your choice, but besides that it would be off topic to this very forum.
Check the usual offerings like crashplan, veeam, etc (we don't know your exact environment and budget)
To my knowledge, the AOMEI Backupper Standard is able to do incremental backup. As for the "keep 7 versions" you talked about, it is true - only Pro and more advanced version support "Backup Scheme".
- storageman
Do you not trust Qsync, that keeps versions?
@Ingrid-C
Yes, I'm using AOMEI Backupper Standard, but the free version.
@storageman
Qsync is cloud, and I wanted some kind of backup/replicator software. It's good at versioning, but I'll use too more storage to use Aomei & Qsync.
@storageman
- storageman
Look at it again, it is not only cloud1inplus wrote:@Ingrid-C
@storageman
- Spider99
as Storageman said look at Veeam - it does incremental, runs on windows (and Linux IIRC)
I use it to backup my windows pc's to my Qnap
Set and "forget"
takes 5 mins to install and setup
and its free
Set and "forget"
and its free
Tim
TS-853A(16GB): - 4.3.4.0483 - Static volume - Raid5 - 8 x 4TB HGST Deskstar NAS
Windows Server + StableBit Drivepool and Scanner ~115 TB Backup Server
TS-412 & TS-459 Pro II: Retired
Clients: 3 x Windows 10 Pro(64bit)
- DanTheMan
But is this backup scheme ransomeware-proof? I'm not so sure.Spider99 wrote:as Storageman said look at Veeam - it does incremental, runs on windows (and Linux IIRC)
If I understand the suggested solution correctly, the NAS is providing storage space through a network share and the backup is carried out by an application running on the Windows client. Therefore the Windows client or the application (e.g., Veeam) have access to the network share. If ransomware infected this Windows client, it could possibly access the network share, too, and encrypt all data on it. Therefore I agree with "Toxic17" who said that a NAS needs to be backup up itself.
In my opinion, a backup scheme is incomplete if it does not protect from ransomware attacks.
- Johnno72
- Easy as a breeze
Nothing worth while or decent comes for Free. All these free software are limited to basic home user not business. I have found that only business software will offer what is needed such as versioning, incremental and full backups, also most free versions will not recognise USB or network shares whereas business versions will and do.1inplus wrote:So, there's no free software for this kind of thing? To do incremental backup, daily, with number of versions, maybe email notification and so on?
OS: Win10 Professional v2004 OS Build 19041.388 x64
NAS: QNAP TS-EC2480U-RP 16G 24 Bay - Firmware: v4.4.3.1421 build 20200907. Updated from v4.4.3.1400 Build 20200817 Official
StoragePool / DataVol: Storage Pool 1 / DataVol1: Single 29.04TB - Thick Volume: 29TB
HDD's: Western Digital - Model: WDC WD4001FFSX-68JUN0 Red Pro NAS 3.5"
HDD Size: 4TB - HDD Firmware all HDD's: 81.00A81
RAID Configuration: RAID6 x 10, HotSpare x 1, ColdSpare x 1 - Network: 1GbE
UPS: CyberPower PR3000ELCDRT2U Professional Rackmount LCD 3000VA, 2250W 2U Line Interactive UPS
QNAP Hardware details required: viewtopic.php?f=5&t=68954
Remote Administration of: TVS-863+ 16G on UPS Cyberpower OLS1500E+RMcard205
- Spider99
Changing the goal postsDanTheMan wrote:But is this backup scheme ransomeware-proof? I'm not so sure.Spider99 wrote:as Storageman said look at Veeam - it does incremental, runs on windows (and Linux IIRC)
Backup can be done to mitigate ransomeware - but that was not the question
Can you provide a better solution?
Tim
