Hi everybody,
here's a drawing of my setup.
The VPN tunnel is established between the left firewall and the TS-453A. Data is mirrored from left to right using RSYNC through a VPN tunnel.
Unfortunately the NAS on the right does not have a publicly available IPv4 address and I failed to successfully setup an IPv6 port forward on the router there. Since QNAP seems to require the rsync job is always started from the source side it needs to start on the left NAS. But because I want the transfers to be encrypted they need to go through a VPN anyway. So the NAS on the right client connects to the firewall on the left and through the tunnel it's available from the left side.
The result is a very stable connection at around 2 Mbyte/sec.. Unfortunately that is not enough to mirror the daily delta of backups. I wouldn't complain if 2Mbyte/sec was really close to the limit of the internet connections. But when logging in to the NAS on the right and downloading something from the left side circumventing the VPN (so directly over the internet), I can get up to more than 3 Mbyte/sec.
The VPN is established with OpenVPN. The firewall is a Sophos UTM on a regular PC. I've already tweaked a bit with the encryption and compression settings to see if that is just overcharging any of the CPUs.
I've played between AES128-CBC and AES256 for the actual encryption and SHA256 to SHA512 for the packet authentication. I did not see much a change in transfer speed. Maybe an improvement of 100kbyte/sec, but nothing close to 3MByte/sec.
The MTU is identical on both sides of the VPN tunnel (1500). CPUs on both VPN endpoints are at less than 50%.
Does anybody have experience with what is possible when going through a VPN over a WAN connection?
Speed of Rsync through VPN
Discussion on remote replication.
Return to “Remote Replication/ Disaster Recovery”
Jump to
- QNAP General
- ↳ Announcements
- ↳ Features Wanted
- ↳ Users' Corner
- ↳ Official Apps
- ↳ Prestashop
- ↳ Webalizer
- ↳ Virtualization Station
- ↳ Notes Station
- ↳ SocialLink Station
- ↳ McAfee Antivirus
- ↳ IT Management Station
- ↳ Container Station
- ↳ Qsirch & Qfiling
- ↳ Community Apps
- ↳ Apps Wanted
- ↳ Partner Apps
- ↳ BitTorrent Sync
- ↳ EZPhone
- ↳ Plex Media Server
- ↳ Ragic
- ↳ Tonido
- Getting Started
- ↳ Frequently Asked Questions
- ↳ Presales
- ↳ Turbo Station Installation & Setup
- General
- ↳ Hardware & Software Compatibility
- ↳ HDD Spin Down (HDD Standby)
- ↳ Seagate Drive Discussion
- ↳ Western Digital Drive Discussion
- ↳ File Sharing
- ↳ Mac OS
- ↳ Linux & Unix (NFS)
- ↳ Windows
- ↳ Backup & Restore
- ↳ Symform
- ↳ Microsoft Azure
- ↳ OpenStack Swift
- ↳ Amazon Glacier
- ↳ Amazon S3
- ↳ WebDAV-based Backup
- ↳ Google Cloud Storage
- ↳ Object Storage Server
- ↳ ElephantDrive
- ↳ Xopero
- ↳ System & Disk Volume Management
- ↳ Web Server & Applications (Apache + PHP + MySQL / SQLite)
- ↳ Download Station and QGet
- ↳ myQNAPcloud service
- ↳ Surveillance Solution
- ↳ Miscellaneous
- ↳ QIoT
- ↳ QuAI
- ↳ QVR Face
- Business
- ↳ Windows Domain & Active Directory
- ↳ iSCSI – Target & Virtual Disk
- ↳ Remote Replication/ Disaster Recovery
- ↳ Server Virtualization & Clustering
- ↳ NAS Management
- ↳ QES Operating System (QNAP Enterprise Storage OS)
- Multimedia
- ↳ Photo Station, Music Station, Video Station
- ↳ Media Streaming
- ↳ Mobile Devices
