Need Some Help on setting up HBS
Discussion on remote replication.
joeofall
Getting the hang of things
Post by joeofall »
Hi all,
few year back i had setup Ts-251 pro for my friend in his office, every thing was fine, till recently 1 of the staff deleted a folder where important and no way to recover it back from the Nas. So i say let another nas to backup it.
I remember with qsync you able to sync 1 way and leave the file on the 2nd nas even file was deleted on the source(1st nas).
i can't seem to find that option now, when i try with Ts-230 (new nas) HBS 3. I tested one way local to local sync, if i delete the file on the source and the target will also deleted.
So how can i setup in such way that, it will just sync the file and leave it there if source file is deleted .
thank you
Joe
owner of ts-210
adminstrator of ts-259 pro + x 2
adminstrator of ts-212
adminstrator of synology ds111
dolbyman
Re: Need Some Help on setting up HBS
Post by dolbyman »
a backup with options to not delete deleted files ..that wouldn't help on ransomware attack .. as those backups still update changed files
joeofall
Post by joeofall »
i can't seem to find that option, anyone had advice please thank you
owner of ts-210
dolbyman
Post by dolbyman »
option is under Rules/Policies
Return to “Remote Replication/ Disaster Recovery”
