I'm having a problem syncing between a TS-809 (4.2.6) and a TS-1232XU-RP (4.5.1.1495) over a WAN link. I have a VPN tunnel established at the firewall level from site A (the 809) to site B (the 1232).
Both RTRR and Rsync jobs, when initiated through HBS, fail randomly. Sometimes after a few hours, sometimes after a few minutes, always the same error, regardless if I do a 809->1232 push or a 1232<-809 pull. The RsyncRR script indicates that this may be a bug:
ERROR_DESC[53]="Encountered error from rsync protocol data stream. Check storage space at destination." # bug 112665 , rsyncd restart
This seems to be a well-known problem (at least, I've seen it discussed here on the forums and elsewhere on the web).
Ideas? I'm completely open to starting a ticket with QNAP.
Thanks!
