HBS via VPN?
HBS via VPN?
Hi all,
I'm quite new to all this stuff here, so in case the question should be too silly, please be kind and gentle...
I have two QNAP systems running, a TS251+ and a TS459 Pro Plus. Both in different locations and networks. I have a rsync replication running between the two NAS, but they of course use the 873 port (default). Now I wanted to make the connection safer by using a VPN connection. I was able to establish a vpn connection via openvpn between both of them (QBelt isn't supported unter TS459 Pro Plus), but: what do I need to do now? The replication job still uses the open default port as mentioned before. So basically, I have the impression that I established a VPN connection without using it. And now?
Thanks and best
Pike
Thanks and best
Pike
Re: HBS via VPN?
i tried to do something similar.
RTRR between two qnaps.
VPN IPSEC/L2TP directly between the 2 qnap.
I never got it working, even not with qnap support.
Speed test was successful, the job started, but stuck at the first file ...
To come this fair ...
I had to put in the first ip of the vpn ip pool as partner address to make it work, so far.
And hoped that the remote qnap will alwayws be the first vpn partner.
I ended up with a direct RTRR connection and enabled TLS on the connection.
Kind regards.
Kind regards.
Re: HBS via VPN?
Assuming you have the VPN working properly, the remote system should be reachable through a remote local IP address instead of the remote public IP address you use now.Pike_Eight wrote: ↑Fri Mar 05, 2021 9:13 pm The replication job still uses the open default port as mentioned before. So basically, I have the impression that I established a VPN connection without using it. And now?
Remember to close the open port in the router/firewall at the remote site when you have it up and running over the VPN.
Re: HBS via VPN?
G’day Pike,
Did you resolve the issue?
Re: HBS via VPN?
I did. VPN works fine. Just wondering why I sometimes receive an error message „server was terminated by a request. Jobs work perfectly fine so no clue why there‘s this error message.
- Moogle Stiltzkin
Re: HBS via VPN?
so what kind of performance through hbs did you get using vpn, just wondering? and what routerPike_Eight wrote: ↑Sun Apr 25, 2021 1:54 pm I did. VPN works fine. Just wondering why I sometimes receive an error message „server was terminated by a request. Jobs work perfectly fine so no clue why there‘s this error message.
NAS
Network
Resources
Network
Resources
Re: HBS via VPN?
Need to check the logs. Earliest tomorrow. But transferred 80 GB during one session. Took time, but worked. Two AVM Fritz Boxes.
- Moogle Stiltzkin
Re: HBS via VPN?
oo mean like transfer speed per sec :}
like when i do a local lan one way sync rtrr i can get somewhere between 80-110 MB/s (110-120 MB/s is roughly the max cap for 1gbe port speed)
80gb is merely the total size i assume, doesn't really tell you much about the transfer speed
you need the size of data being transfered per sec on average. usually once the transfer completes, you get the overall average speeds for that job.
Last edited by Moogle Stiltzkin on Sun Apr 25, 2021 3:29 pm, edited 1 time in total.
NAS
Network
Resources
Network
Resources
Re: HBS via VPN?
I know. Just wanted to express that the transfer happened at a reasonable time. Didn‘t check the transfer rate, though. I‘ll do maybe tom.
- Moogle Stiltzkin
Re: HBS via VPN?
ty i appreciate it. because i also am curiousPike_Eight wrote: ↑Sun Apr 25, 2021 3:29 pm I know. Just wanted to express that the transfer happened at a reasonable time. Didn‘t check the transfer rate, though. I‘ll do maybe tom.
NAS
Network
Resources
Network
Resources
Re: HBS via VPN?
That is great to hear. Did you get any of these issues?Pike_Eight wrote: ↑Sun Apr 25, 2021 1:54 pm I did. VPN works fine. Just wondering why I sometimes receive an error message „server was terminated by a request. Jobs work perfectly fine so no clue why there‘s this error message.
viewtopic.php?f=15&t=158069
Regards
Re: HBS via VPN?
Sorry, fortunately for me but unfortunately for you I didn't came across these issues.
Re: HBS via VPN?
Thanks for that Pike. So you successfully got the VPN client to back up data onto the VPN server’s volume? This you had previously set up using Rsync and allowing the port-forwarding on the NAS , as NAS to NAS?
Regards
Regards
Re: HBS via VPN?
Okay, I have been working with QNAP support to help resolve the issues.
Support advised that I need to enable “use vpn as nas default gateway ” on NAS B which is set up as an Open VPN client in QVPN. The place I want to back up files to is NAS A which is running QVPN Open VPN server.
This worked, and when I select an rsync/rtrr remote server it shows NAS with its local 192.168.0.200 ip. No passwords or anything is then required. Tests were successful. I think this also means that when I installed a new app, it collects it via the vpn through NAS A and then access to big wide world.
Remaining issues, cannot get the reverse to work, so cannot see NAS B as local to NAS A. more work for support.
Regards
Regards
- Moogle Stiltzkin
Re: HBS via VPN?
my misunderstanding. i updated post accordingly
probly should enable SSL in hbs server ya? since doing remote
Last edited by Moogle Stiltzkin on Thu Apr 29, 2021 7:23 am, edited 2 times in total.
NAS
Network
Resources
Network
Resources
