How to recover a TS-x73 from endless boot sequence?
Discussion on remote replication.
Almyn
First post
Post by Almyn »
My TS-673 had started to endlessly reboot. What I have done sofar:
– removed the PCIe card (all further tests were conducted without this card inserted). Same results
– removed the disks. Same results
– booted only with the 2 x 2 GB sodimms in slots 1 and 3, with and without disks. Same results
– booted only with the 2 x 8 GB sodimms in slots 1 and 3, with and without disks. Same results
I could not find a way to reflash the firmware for this model, so I have files a support request. I have copied my key-backups to another system, I gather I could miss the less important files. While that is true, it still hurts. I got some questions because I want to prepare for the worst (the darn thing will never come to live again):
- I tried to figure out how to reinstall the firmware. It seems that that is not possible on this model
- I wondered if it is possible i take out the disks and install in another system. I found this page and my model is not mentioned
Because of the two limitations mentioned above I wondered if the TS-x73 is not such a good model (stronger words scrapped) or whether I miss something?
My current configuration of the TS-673 since about a year:
– 4 x 3 TB disks in raid 10 configuration, 1 TB unused spare
– the original 2 x 2GB memory, 2 x 8GB crucial sodimms
– QM2 – 2P10G1T, with 2 1TB nvme SSD’s
Trexx
Ask me anything
Re: How to recover a TS-x73 from endless boot sequence?
Post by Trexx »
You really need an small Nvidia GPU card like a 1030/1050 installed so you can see what the error is.
Try holding reset button in for like 10 (?) seconds does a full system config wipe so could try that as well.
Hopefully you have backups of critical data just in case data on drives was affected.
Paul
UPS: CP AVR1350
dolbyman
Post by dolbyman »
Also, this here is the migration guide (to move the dlsks over if the nas is bust)
https://www.qnap.com/en/nas-migration
Return to “Remote Replication/ Disaster Recovery”
