How about a New File Manager?
Tell us your most wanted features from QNAP products.
acpiper
Postby acpiper » Sat Apr 15, 2017 1:32 am
Love to see a dual column file manager - something explorer-like that lets me drag and drop from column a to b, delete on the fly, handle permissions, etc. Everything that a person needs to do with files all on one screen
Don
Contact:
Re: How about a New File Manager?
Postby Don » Sat Apr 15, 2017 2:42 am
Try winscp.
Read the Online Manuals and use the forum search feature (upper right hand corner) before posting.
It is a recommended to use RAID and have external backups. RAID will protect you from disk failure, keep your system running, and data accessible while the disk is replaced and the RAID rebuilt. Backups will allow you to recover data that is lost or corrupted, or from catastrophic system failure. One does not replace the other.
Bugs and feature requests need to be submitted to QNAP via their Helpdesk or Helpdesk app.
NAS: TVS-882BR | F/W: 4.3.3.0361 | 40GB | 2 x M.2 SATA RAID 1 (System) | 2 x M.2 NMVe RAID 1 (Cache) | 3 x 4TB HDD RAID 5 (Data) | 1 x Blu-ray
NAS: TVS-663 | F/W: 4.3.3.0361 | 16GB | 2 x M.2 NMVe QM2 RAID 1 (Cache) | 3 x 4TB RAID 5
N/W: Netgear NightHawk R7800 router | SMC gigabit switch
schumaku
Contact:
Postby schumaku » Sat Apr 15, 2017 6:39 pm
Why an inflexible and aged dual column design if we can open two, three, ... File Station views - and everything is fully interoperable?
I_HATE_QCRAP
First post
Postby I_HATE_QCRAP » Thu May 25, 2017 7:26 am
What about a file manager that actually allows you to manage files and folders?
For example, be able to Create, Delete, Copy, Move, etc, files and folders in a SINGLE window. Without having to open the Control Panel to delete folders (but NOT the ACTUAL folders/files if you didn't know this trick - leaving a load of now hidden rubbish taking up disk space). Oh.....and you have to open Storage Manager to see how much disk space is used/available.
How about a new PROJECT MANAGER? I mean an actual person who is capable of overseeing the DESIGN of a system, such that there's a remote chance of it being usable.
schumaku
Contact:
Postby schumaku » Thu May 25, 2017 8:13 pm
I_HATE_QCRAP wrote: be able to Create, Delete, Copy, Move, etc, files and folders in a SINGLE window
Except of creating a file everything is possible, even in a single File Station window. The destination folder can be in the left folder tree pane as well as in the right folder and file pane.
I_HATE_QCRAP wrote:Without having to open the Control Panel to delete folders ...
Assume you talk of shared folders ... We can dispute why the creation of Shared Folders was added to the File Station, but not the removal of a shared folder - yes, this is inconsistent.
I_HATE_QCRAP wrote:(but NOT the ACTUAL folders/files if you didn't know this trick - leaving a load of now hidden rubbish taking up disk space).
Removing a shared folder does query to delete the data:
Criticism where criticism belongs. And no, I'm not a PM.
The File Station scope is intentionally limited the existing Shared Folder scope - neither to a full volume access, nor to a NAS system access.
Regards,
-Kurt
OneCD
Experience counts
Postby OneCD » Fri May 26, 2017 3:17 am
schumaku wrote:The File Station scope is intentionally limited the existing Shared Folder scope - neither to a full volume access, nor to a NAS system access.
Which I agree with and is a very good idea. Newbs can't inadvertently affect the OS. And those who really want-to can work out how-to. :geek:
I_HATE_QCRAP wrote:For example, be able to Create, Delete, Copy, Move, etc, files and folders in a SINGLE window. Without having to open the Control Panel to delete folders (but NOT the ACTUAL folders/files if you didn't know this trick - leaving a load of now hidden rubbish taking up disk space). Oh.....and you have to open Storage Manager to see how much disk space is used/available.
QNAP's File Station is good for basic operations and will allow you to perform simple NAS file management. When you outgrow it, use your own file manager instead.
I've switched to pure Debian on my production NAS (TS-569 Pro), with the backup NAS (TS-559 Pro+) to follow, so I'll no longer be able to use or support QNAP's firmware. This means no more closed-source software, "Malware Removers", etc ... If you have the means, I highly recommend it. Powerup/poweroff times are < 1 minute. :D
one.cd.only@gmail.com
Johnno72
Know my way around
Postby Johnno72 » Fri May 26, 2017 6:29 am
I've been lurking in this thread waiting to see where it would go, glad I did. I do a heck of a lot of file management 24/7, so far majority of that has been on the computer side, then move it to the NAS, having a proper File Manager on the NAS itself would be great as I have a lot of file work on that to do. QNAP's File Manager to me is an ok kind of start but it too needs a complete 360 degree make over for it to be useful. Now there is a folder on there I can't even delete.. research time for that - just found the info. and done
OS: Windows 10 Pro Insider Preview Build 17035.rs_prerelease.171103-1616 x64
NAS: QNAP TS-EC2480U-RP 16G 24 Bay Rackmount - Firmware: 4.3.3.0361 Build 20171101
StoragePool / DataVol: Storage Pool 1 / DataVol1: Single 29.04TB - Thick Volume: 29TB
HDD's: Western Digital - Model: WDC WD4001FFSX-68JUN0 Red Pro NAS 3.5"
HDD Size: 4TB - HDD Firmware all HDD's: 81.00A81
RAID Configuration: RAID6 x 10, HotSpare x 1, ColdSpare x 1 - Network: 1GbE
UPS: CyberPower PR3000ELCDRT2U Professional Rackmount LCD 3000VA, 2250W 2U Line Interactive UPS
QNAP Hardware details required: https://forum.qnap.com/viewtopic.php?f=5&t=68954
schumaku
Contact:
Postby schumaku » Fri May 26, 2017 7:22 am
Johnno72 wrote:QNAP's File Manager to me is an ok kind of start but it too needs a complete 360 degree make over for it to be useful
Such as? When turning 360 degrees you are on the same heading again, isn't it? At least on the northern hemisphere. :shock:
Johnno72 wrote:Now there is a folder on there I can't even delete
If you talk of the shared folder level, it's more than just a folder. Seriously, how many times you have to create resp. remove shared folders?
Johnno72
Know my way around
Postby Johnno72 » Fri May 26, 2017 7:37 am
Yes, it means a complete new start, do over, start from the beginning.. lol
If you talk of the shared folder level, it's more than just a folder. Seriously, how many times you have to create resp. remove shared folders?[/quote]
1. I didn't create the folder personally, software change of data path created it and I know which one,
2. I never use Guest Accounts period and that is what threw me and when it stated garbage like Guest security details required, I was like WTF... that is why I said I doing bit of research on this, and I worked out the what's, how's, and why's under 5 minutes and edited to say so. I am still diving deeper into my QNAP and learning, tweaking to how I want it not the Default Wizard settings I used on initial setup
schumaku
Contact:
Postby schumaku » Fri May 26, 2017 7:46 am
Johnno72 wrote:1. I didn't create the folder personally, software change of data path created it and I know which one,
Beyond me what or how this is related with the File Manager. "the folder" ... uh, waht, pleeeeeease?
Johnno72 wrote:2. I never use Guest Accounts period and that is what threw me and when it stated garbage like Guest security details required, I was like WTF... that is why I said I doing bit of research on this, and I worked out the what's, how's, and why's under 5 minutes and edited to say so. I am still diving deeper into my QNAP and learning, tweaking to how I want it not the Default Wizard settings I used on initial setup
Guest account? It's required for some operations ... but the account is never used for a login.
Default Wizard? Should you try to tweak the default shared folders, well - this is ways beyond the File Station. A new file manager won't change anything - as it does not change the QNAP design.
I'm lost what you try to explain here.
hubb_99
Postby hubb_99 » Sat Sep 23, 2017 2:50 am
"When you outgrow it, use your own file manager instead."
Well......what ones? I tried WinSCP and I think it blows. Using Windows Explorer would be nice but it's a bit slower due to Samba as I understand. I would love something with all the functionality of the WIN10 explorer because I really think they nailed it this time.
schumaku
Contact:
Postby schumaku » Sun Sep 24, 2017 5:36 pm
Aware File Station is a Web Applications, not a fully fledged Windows or whatever thing?
hubb_99 wrote: I would love something with all the functionality of the WIN10 explorer ...
Aware File Station is a Web Applications, not a fully fledged expandable binary application with direct access to a capable UI environment?
Functionality such as what exactly please?
Return to “Features Wanted”
Who is online
Users browsing this forum: No registered users and 2 guests
