Secure erase of hard drives
It would be very useful if QTOS supported securely erasing hard drives by writing random data over it a specified (i.e. 0-10) number of times.
- Moogle Stiltzkin
Re: Secure erase of hard drives
on desktop i use privazer. i heard in a future version they MAY support NAS as well.
http://privazer.com/
[youtube=]kOZchMvGbj4[/youtube]
until then.... what i normally do if i wanted to really do a clean wipe. I format via QNAP. when done, i pull out all the hdds then use my HDD dock station which is connected to my desktop. I can then run privazer and wipe it that way via connected usb device selection
hdd docks are really useful (for my own use i use it for diagnosing issues with hdd using other third party apps which can only be run from desktop pc, or just a quick way to access a HDD), i recommend getting one
NAS
Network
Resources
Network
Resources
- OneCD
You might also checkout shred. Available through the Entware-3x QPKG.
- Moogle Stiltzkin
or if your intending for permanently getting rid of a broken hdd there is the actual shredding itself
[youtube=]rV4EvvgkZrQ[/youtube]
[youtube=]wb3Xa1h_RqM[/youtube]
NAS
Network
Resources
Network
Resources
- schumaku
Trouble is that secure erasing HDDs (or SSDs) is hardly possible if the units are broken or run-out. SSD might block writing completely once the number of allowed writes is hit, too. For storage blocks going to re-usage or sales, a secure erase is better done off the NAS, because commonly the NAS has to return to service ASAP.
And for you serious types:
[youtube=]WOdZkSdNKSM[/youtube]
- Moogle Stiltzkin
4.3.4 added a feature for securely erasing hard drives.alxrmrs wrote:It would be very useful if QTOS supported securely erasing hard drives by writing random data over it a specified (i.e. 0-10) number of times.
Secure Erase
Secure erase permanently deletes all data on a disk, ensuring that the data is unrecoverable. Using secure erase on an SSD also restores the disk's performance to its original factory state.
To begin, select a free disk, and then select "Action" > "Secure Erase". In the Secure Erase Wizard, follow the instructions to specify other disks to erase and the erase method.
If all disks in the NAS have been selected for a secure erase, a full NAS system re-initialization is required.
*Note: During the secure erase process, do not unplug any disks, or power off or restart the NAS. This ensures disks are fully erased and can be used again afterwards.
NAS
Network
Resources
Network
Resources
Awesome, thanks for the feature QNAP! Hopefully this will work on my failing drives so I can throw it out. I'll find out this week.
If the SMART information says "Warning" secure erase is not available under actions. Is there a way to override this?
if the drives are failing and are just tossed out .. why go through a secure erase? .. a nail through the top cover works faster and is more secure
- schumaku
The Secure Erase is available for "free" disks only - disks not used in a storage pool or holding a legacy volume. A control the "Free" a disk (remove from a redundant RAID) to secure erase and replace for rebuilding the RAID does not exist unfortunately. Please support the "Free" disk control addition feature request by filing tickets on https://helpdesk.qnap.com/ mentioning MantisBT 28413.alxrmrs wrote:If the SMART information says "Warning" secure erase is not available under actions. Is there a way to override this?
Is it possible to set the disk as free even though the SMART status is warning? Under SMART it does say that the disk should be operating properly.
I would like to know if this is possible too. I have a drive that is working, but it listed as "warning." I'm replacing it (since it's less that 30 days old) but I'd like to wipe it before I send it back. Any way to do this in the NAS?alxrmrs wrote:Is it possible to set the disk as free even though the SMART status is warning? Under SMART it does say that the disk should be operating properly.
Did you get the solution for this? I am in the same boat. have to return the hard disk after wiping all the data.oldWindowsGuy wrote: ↑Tue Oct 09, 2018 12:36 pmI would like to know if this is possible too. I have a drive that is working, but it listed as "warning." I'm replacing it (since it's less that 30 days old) but I'd like to wipe it before I send it back. Any way to do this in the NAS?alxrmrs wrote:Is it possible to set the disk as free even though the SMART status is warning? Under SMART it does say that the disk should be operating properly.
sadly the "safe erase" option is not available for external drives :/
