Running more than one copy/move operation at a time results in them being processed in parallel which is very inflexible. I would like to see the tasks worked on sequentially and listed with an option to pause/cancel/promote or demote any one as desired. I see this has been requested in the past but not found its way into the current release.
Please give this some attention soon. Thanks.
Better Control Over Background Tasks In File Station
My system: PC running Win 10 x64 / i7 processor with 12 Gb RAM/ Gigabit wired LAN / ZTE F660 fibre modem-router in bridge mode / Asus DSL-N55U_C1 Router / QNAP TS651. Drives arranged as Vol 1=2 x 4Tb WD Red mirrored RAID 1; Vol 2 = 1 x 6Tb WD Red Single; Vol 3= 1 x 2Tb Seagate Single; Vol 4 2 x 4Tb HGST RAID 1;
- Moogle Stiltzkin
Re: Better Control Over Background Tasks In File Station
make sure you also create a ticket here to forward the request
https://helpdesk.qnap.com/
though i find it easier making support ticket from qts since it auto fills some what.
but isn't parallel processing better ? since it speeds up processing versus a sequential method ?
at least in web design i find that the scripts worked better when i could parallize when possible.
i can imagine though if your transferring many items in paralel in the background tasks gui, it could easily be a long list. so maybe a scrolled window to help browse the items running in parallel (to keep the scrolled list short but scrollable) ? i hadn't tested moving that many items before to know how exactly it will look. maybe you could screenshot and post to share here and in the support ticket as reference
NAS
Network
Resources
Network
Resources
I would say that if you are copying say 10 large files and you don`t use sequential copying your hard drive head would be moving so much you would be getting nowhere.but isn't parallel processing better ? since it speeds up processing versus a sequential method ?
I`m a plus one on the task queue idea !!!!!!
You are already providing the answer to your question: "at least in web design" = whether parallel or sequential is better depends on your use case and hardware.Moogle Stiltzkin wrote: ↑Sun Jun 18, 2017 8:29 am but isn't parallel processing better ? since it speeds up processing versus a sequential method ?
Many small files and fast disks (even SSDs in full or for caching) => parallel is usually better.
Large files and slow disk (rust and maybe even SMR) => sequential is better.
There should be an option for admins or users to decide.
"option", because there is no way for QNAP to know use case and hardware in advance, so they cannot make a good guess.
"should be", because the difference is substantial if you are doing it wrong.
In fact: I found this thread because I was looking for a way to queue copy jobs.
I use my NAS as a video box. Accordingly I have large files and cheap disks = SMR.
Starting multiple jobs that are not queued but run in parallel is, ahem, not a great experience.
p. s.: For this very reason I use a file manager that can handle jobs in queues to get data onto the NAS (Path Finder vs. macOS default Finder). But of course copying data with File Station is sometimes preferable. And then a queue-feature would be greatly appreciated.
2x QNAP TS-431P2, 1x QNAP TS-212P
Firmware current as provided by qnap
Various Seagate 8 TB HDDs (w/ and w/o SMR) configured as single disks
DLNA via Twonky. Replication via RTRR.
Me too,In fact: I found this thread because I was looking for a way to queue copy jobs
I have ftp/sftp applications which are great for transferring to and from the NAS, but use File Manager with Hybrid mount to copy between NAS. The ability to queue, pause and resume should surely be available in 2020!
Cancelling a job and then setting it up again generally makes a mess of your files even if you select skip existing files.
TS-453d
QTS 5.0.1.2277 build 20230112
TS-869 Pro
QTS 4.3.4.2242 build 20221124
TS-869 Pro
- OneCD
