Please integrate the Qfile to iOS file app, like what other could storage provider do.
Qfile integration for iOS file app
- OneCD
Re: Qfile integration for iOS file app
Hi and welcome to the forum.
It looks like you're using the iOS 'Files' app. Qfile is already supported within this app, but you have to enable it as a location. Follow the red boxes:
This works on the iPhone, but on the iPad, I don't have the "Qfile Location" that I could enable. Any Suggestions?
Thanks!
Thanks!
- OneCD
This may be a silly question, but have you installed the Qfile app on your iPad?rhuebscher wrote: ↑Fri Jan 11, 2019 12:15 am ... I don't have the "Qfile Location" that I could enable.
