Qnap TS-453 Pro Kodi Not Open
Kilumiranda
Post by Kilumiranda »
Hello people,
I have Qnap TS-453 Pro and recently updated Firmwere to version 4.4.1.1081 as well as HybridDesk Station (HD Station) version 4.0.3.
Since when qnap restarted I left Kodi version 15.2 and 17.0 installed on Qnap, I often used version 15 but currently I have neither installed. I did the installation of Kodi version 17, installed in Qnap but when I click to open the app nothing happens (does not open).
I installed Kodi version 18 Alpha when I click on APP doesn't open either.
They can help me.
Thanks.
Khondo
Re: Qnap TS-453 Pro Kodi Not Open
Post by Khondo »
Same problem
patricepm
Getting the hang of things
Post by patricepm »
Hi all,
Here, the same problem. :(
QNAP TVS-473
- 4x WD Red Pro 6TB (RAID 10)
- 2x WD SA510 1TB (RAID 1)
- 2x Samsung 970 Evo plus m.2 1TB (RAID 1)
- 40GB Memory
- Firmware: QTS 5.1.1.2491
patricepm
Post by patricepm »
Ok, this is what I did today....rolled back to HD Station 4.02 and Kodi works again.
My QTS is as stated in my signature and also had updated HD Station to 4.1 what broke Kodi for me. I had HD Station version 4.02 laying around so uninstalled 4.1, and installed 4.02. On top of this I've re-installed Kodi 18.4 and now all is working again.
I goes I stay away for a while from HD Station 4.1 until I read positive feedback Kodi is working.
Perhaps this will work for you guys too?!?
QNAP TVS-473
- 40GB Memory
weekendwarrior
Post by weekendwarrior »
patricepm wrote: Sun Nov 17, 2019 2:50 am Ok, this is what I did today....rolled back to HD Station 4.02 and Kodi works again.
Any chance you can share that older version? I ran into the same issue but qnap won't post any older versions.
Thanks a bunch
Kilumiranda
Hi
On the site https://www.qnapclub.eu/en/qpkg/677 made available the new version of Kodi, Kodi Leia.
My HD Station 4.0.4 I installed Kodi and it works fine.
neilmelvillekenney
First post
Post by neilmelvillekenney »
Kilumiranda wrote: Mon Nov 18, 2019 3:42 pm Hi
This works fine for me too. Running HD Station 4.0.5. Thank you!
kochlik
Post by kochlik »
Hi patricepm, any chance you can share HD station 4.0.2 for model 473? I'm running also this model and ever since HD station 4.1 none of the players work. I tried downgrading, but didn't find download for older HDS. Qnap offers 4.0.5 but it is useless. Probably due to the fact that the download is not compiled for 473. For 473 model only 4.1 is available.
Thank you
math
Post by math »
try installing NVIDIA Drivers
it should do the trick
Keufke
First post
Post by Keufke »
math wrote: Sat Jan 11, 2020 7:00 pm try installing NVIDIA Drivers
How can you update them? I have the same issue that Kodi won't open. I have already tried the Kodi versions from Qnap club but I'm not able to use them. I downgraded HD station to 4.06. but this also didn't work. I have a tvs-673
patricepm
Post by patricepm »
Hi all,
Sorry for the late reply.
I've recently updated HD Station to the latest version and also installed Kodi v19 but still no luck running Kodi. Kept showing Kodi is starting but within a few seconds it stops as if nothing is going on. So, I've Un-Installed the latest version of HD Station and Installed HD Station version 4.0.2 again together with Kodi v19 and all is running.
I've placed HD Station 4.0.2 in a dropbox folder for you to download, I hope it'll work for you the same as for me.
https://www.dropbox.com/s/4hpbs93cqwypm ... .qpkg?dl=0
QNAP TVS-473
- 40GB Memory
bbottema
Post by bbottema »
patricepm wrote: Sat May 23, 2020 3:20 am Hi all,
You saved me!
felixino
Post by felixino »
Thank you! I hade the same issue, HD Station > 4.02, tried up to 4.1.1 without success. Then I removed HD station, download 4.0.2 from https://download.qnap.com/QPKG/HDV3/Gen ... 190125.zip
reinstall kodi 19 and it works!
FW 4.5.4.1741
kodi 19.1.0.0
HD Station 4.0.2
Kilumiranda
Thank you All.
Bixby
Post by Bixby »
I am having the same issue but I don't know how to revert to a prior version of HD Station. Isn't HybridDesk Station a group? How do I do that.
Return to “Users' Corner”
