Rsync "Module" Support
Tell us your most wanted features from QNAP products.
kherr4377
Been there, done that
Post by kherr4377 » Wed Apr 14, 2021 12:07 am
Pleeeeeeeease add Rsync Module support like the rest of mankind ........
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
grouillier
Re: Rsync "Module" Support
Post by grouillier » Thu Apr 22, 2021 10:48 am
I found this post by search, and I think I'm encountering the same issue, though the OP's post is ... brief :). Here's my more verbose version.
I just got a TS-230, and still learning to use it. I tried out QSync but don't like that it litters my client system with .qsync directories, and also creates a massive directory of all files on the NAS in my home directory (under Windows, /Users/<username>/AppData/Local/QNAP/Qsync). So I decided to switch to rsync. (For Windows users, you can also use RoboCopy, which I've been using for decades. I thought I'd switch to rsync which I can also using with Linux.) I got it working, but I spent a lot of time fighting with using rsync modules. Here's what happens when I try to use a module:
rsync -rtv admin@nas::Public/Projects-Linux/ Projects-Linux
rsync: [Receiver] failed to connect to nas (192.168.2.95): Connection refused (111)
rsync error: error in socket IO (code 10) at clientserver.c(137) [Receiver=3.2.3]
If instead I use the directory to the public folder directly, rsync works fine:
rsync -rtv admin@nas:/share/CACHEDEV1_DATA/Public/Projects-Linux/ Projects-Linux
I second the OP's request for module support.
TS-230, QTS 4.5.2, single 3 TB Western Digital Red Plus
elvisimprsntr
Easy as a breeze
Post by elvisimprsntr » Thu Apr 22, 2021 12:28 pm
Too many “:” in first attempt
Also you need to specify the path from the default directory for the admin account.
Why not use the built in Hybrid backup GUI interface?
QNAP support does not read this forum
[Hourly] TS-453A-16G, R5x4x2TB Seagate ST2000VN00?, Crucial CT2KIT102464BF160B
[Daily] TS-253A-16G, R1x2x4TB Seagate ST4000VN008, Crucial CT2KIT102464BF160B
[Weekly] USB3, 1x4TB Seagate STDR4000901, 45 min fire rated safe
[WAN1] ATT Fiber
[WAN2] SpeedTalk SIM in Netgear LTE Modem
[Firewall] pfSense on Protectli
[WLAN] OpenWRT on Linksys WRT3200ACM
[UPS] APC Back-UPS BX1500G
Return to “Features Wanted”
