Disk temperature monitoring widget mod
Tell us your most wanted features from QNAP products.
Locked
jaunais2
Post by jaunais2 »
Hello QNAP team
I recentry monitoring Disk temperature (this summer are hot).
And for continuity view temperature status I drag & drop to desktop "Disk health" widget.
Problem is this widget height:
- I have TS-653D + QM2 expansion Card and totaly NAS have 8 disks, but widget does not display everything at once - widget height is only 111px (shows only 4 disks at once), and i need to use scrollbar for monitoring.
Can You redesign css for this widget for automatic heigth, or make this height px in calculated, based on disk count in system?
I temporary use browser User CSS option with that css
#widget-QHDDHealth .x-panel-body {
  height: 211px !important;
#widget-QHDDHealth .x-panel-body > div {
#widget-QHDDHealth .x-list-wrap.hdd-list.soho.overflow-hidden.x-abs-layout-item {
	overflow: visible !Important;
After that i can view temperature for all my disks in one widget w/o scrollbar.
OneCD
Re: Disk temperature monitoring widget mod
Post by OneCD »
jaunais2
Post by jaunais2 »
OneCD wrote: Fri Jun 25, 2021 3:33 am viewtopic.php?f=24&t=161411
Done
Locked
Return to “Features Wanted”
