Hello lads and gents,
I just recently bought a TVS-h674. I wanted to use it quiet heavily for virtualization. However I ran into the ram issues pretty quickly because I did not know that the ARC Service is reserving itself 80% of the ram by default settings.
I personally dislike the configuration in percentage (why not just in GB and freely selectable).
After I found that issue, I upgraded the nas from 32 to 64 GB. But with that upgrade it seems even more crazy how much is reserved for that service because the lowest I can set it to is 40%.
So with 64GB RAM it permanently reserves ~24-25GB RAM.
Can we please get a more precise option to set the reserved RAM for that. Or at least give us the option to set it to 20%. With 64GB installed there is still plenty enough ram reserved for that service.
ARC-RAM Usage (Percentage)
Re: ARC-RAM Usage (Percentage)
You know what else is crazy ?
People not reading sticky's
viewtopic.php?f=24&t=161411
Thread > closed
Thread > closed
