Hi
i got the followinf error after firmware upgrade to 4.2.1 2016/06/01.
[/mnt/ext] # df -h
Filesystem Size Used Available Use% Mounted on
/dev/ramdisk 32.9M 17.3M 15.6M 53% /
tmpfs 64.0M 380.0k 63.6M 1% /tmp
/dev/sda4 371.0M 366.9M 4.1M 99% /mnt/ext
/dev/md9 509.5M 158.9M 350.5M 31% /mnt/HDA_ROOT
/dev/sda3 915.4G 538.2G 376.7G 59% /share/HDA_DATA
CloudDrive 2.0M 2.0M 1.0M 67% /mnt/rf/cd
tmpfs 1.0M 0 1.0M 0% /mnt/rf/nd
df: /share/external/Etron xHCI Host Controller: Protocol error
any Idea?
can i delete form /etc/mtab?
thanks
Re: df: /share/external/Etron xHCI Host Controller: Protocol erro
I'm getting these errors after upgrading to 4.2.4 Build 20170313.
Were you able to find a solution?
Found out it's related to PhotoStation:
[/] # mount -l
/proc on /proc type proc (rw)
none on /dev/pts type devpts (rw,gid=5,mode=620)
sysfs on /sys type sysfs (rw)
tmpfs on /tmp type tmpfs (rw,size=32M)
none on /proc/bus/usb type usbfs (rw)
/dev/sda4 on /mnt/ext type ext3 (rw) []
/dev/md9 on /mnt/HDA_ROOT type ext3 (rw,data=ordered) []
/dev/md0 on /share/MD0_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,noacl) []
gphotofs on /share/external/Etron xHCI Host Controller type fuse.gphotofs (rw,nosuid,nodev)
If you are not using PhotoStation you may umount it (umount gphotofs).
It does not get umounted if you stop (or even remove) PhotoStation app.
[/] # mount -l
