App Default volume does not exist
I receive this error while trying to install a new app on my QNAP.
[App Center] App Default volume does not exist. Please go to "Storage Manager" to create a new volume before installing apps.
I have one Pool and one volume taking up 100% of that pool, not sure why its throwing this error? Since I have no room on the pool I can't create a new volume.
I have a TS-870U-RP running 4.2.2 Build 20160901
Any ideas would be great
- storageman
Re: App Default volume does not exist
Does your current volume say "(System)" after the name?
The Storage pool is called "Storage Pool 3" and the volume is called "-sspfile", I don't see anything that says System in the storage manager area.
- storageman
Raise a ticket.
So you removed the first volume at some point. Have you rebooted since then?
If you removed the system volume you have to reinstall any apps previously installed on it or new apps on another volume.
Not sure why you're getting error then.
We revamped the array a few months ago and have rebooted since. Rebooted a week ago as well since new FW was just released. I guess I'll call support.
having also [App Center] App Default volume does not exist. Please go to "Storage Manager" to create a new volume before installing apps.
Yes i rebooted, migrated to datavol2 deleted afterwards datavol1 so it seems thats the issue. But how to solve this?
Just wanted to update everyone one that might find this.
The fix was: Go to QNAP GUI > Control Panel > Privilege Settings > Shared Folders to click [Restore Default Shared Folders].
Thanks for posting the fix! Sorted my issue as well. Love you man!!!
I realize this is old but THANK YOU THANK YOU THANK YOU!!! Could they have hidden this any better?akeohan wrote:Just wanted to update everyone one that might find this.
Gosh !!! I was about to reset the NAs. THANK YOU FOR THE FIX. You saved me 3 days work.
Good lord. Thank you so much for this fix.akeohan wrote:Just wanted to update everyone one that might find this.
Does the steps will reset the permission on all shared folders to the default?rahulabhatia wrote: ↑Mon Sep 03, 2018 7:58 pmGood lord. Thank you so much for this fix.akeohan wrote:Just wanted to update everyone one that might find this.
I have several Shared Folders which has many user's account assigned on.
I just worry it will reset all access permission on those Shared Folders
thank you
- Easy as a breeze
Why that strange error that the OP got for not having the default folders?
The default folders seem very important to QTS, for some reason
NAS: TS-453Be
RAM:Crucial 8GB Kit (2 x 4GB) DDR3L-1600 SODIMM CT2KIT51264BF160B
QTS: 5.1.4
HDD's: RAID 6: Four 8TB WD Red (WD80EFAX)
USB HDD: One 12 TB WD Elements (WDBWLG0120HBK-NESN)
Switch: Netgear GS108
QTS: 5.1.4
You saved my Weekend!!
I had this problem after putting 4 Drives in bays 1-4 and, new ones in 5-9
After copy-session: I got off the old ones and put the new ones into 1-4.
Booting took a while, but finally I got it working.
But there was still the old RAID in controllpanel/storage.
I even managed to delete that corpse but endet in neither beeing able to install apps nor copy data to the NAS
Your solution cleared that issue
Thank Yuu very much!!!
Klausi
Klausi
NAS1: TS-419P II, 4*3 TB
NAS2: TS-451, 4*4 TB, 4GB
YOU SAVED MY WEEKEND! Thank you!!! Such an obscure fix, QNAP you **!
