I have a TS451 filled with 4x 1 TB HDDs RAID 5, nearly full.
I would like to upgrade to a 2x 6 TB Raid 1 plus 2x 128 GB SSD for caching.
I am wondering how I could make it without loosing data.
Does anybody have an idea ?
Is that working :
- copy all the data to one of the 6 TB disk through USB
- stop the NAS and remove all 1 TB HDDs
- insert the 6 TB disk (clean without data) as a JBOD disk
- copy back the data from the external USB drive
- insert the other 6 TB drive to create the mirror (after copying the datas)
Thanks for your help ?
TS451 - upgrading drives / raid keeping the data
- Don
Re: TS451 - upgrading drives / raid keeping the data
Backup data. Recreate system from scratch. Restore data.
Thanks Don.
But that would mean having a third HDD for backup.
Is my method described working ?
- backup all the data through USB
- stop the NAS and remove all 1 TB HDDs, restart system from scratch
- insert one 6 TB disk (clean without data) as a JBOD disk
That would mean I can use one of the 6 TB HDDs as a temporary external drive for backup/restore
- Don
It will work but not advisable. If something goes wrong after you insert the second drive while the raid is building you will lose you data as you don't have a backup. You should be doing backups anyway so why not get a drive for that purpose. See my signature.
Also what are you using your system for that you think caching will be of benefit?
OK thanks for the advice.
I use the NAS for backups, large directory syncing, and multimedia files sharing.
But I have a low speed (below 15 MB/s), even on 1 Gb network (wired). I thought that HDDs were the bottleneck, but not easy to diagnose.
- Spider99
i would sort the network issue first before you do anything - the cache will not help your network speed
are you sure all your network and router are 1gig sounds more like 100mbit
Tim
TS-853A(16GB): - 4.3.4.0483 - Static volume - Raid5 - 8 x 4TB HGST Deskstar NAS
Windows Server + StableBit Drivepool and Scanner ~115 TB Backup Server
TS-412 & TS-459 Pro II: Retired
Clients: 3 x Windows 10 Pro(64bit)
- Don
Agreed. I doubt this is a disk transfer speed issue unless of course the drives are really really old and transfer at SATA I speeds.Spider99 wrote:i would sort the network issue first before you do anything - the cache will not help your network speed
computers, NAS and network switch are 1 Gb - verified on the switch management interface
Tools used for transfers are TimeMachine on Macos Sierra, Robocopy on WIndows (through SMB shares), or Windows explorer copy (Windows 7).
Disks are SAMSUNG HD103UJ (SATA 3 Gbps)
- Spider99
download the qnap diagnostic tool and test your disks
what speeds do you get?
do you have encrypted volumes or folders? have seen poor network performance due to folder encryption 40MB/s vs 110MB/s on same nas
Tim
I have no encrypted volumes.
I have between 80 and 105 MB/s on my 4 HDDs, I assume I should have better perfs on my shares.
- Spider99
not great speeds but adequate
do a simple test - copy the single largest file you have from the nas to a pc/mac and then copy it back
what network speeds do you get and how big is the file
Tim
