My NAS is non accessible and showing the below indefenite status sequence, any help is much appreciated.
- Green Power LED flashes slowly,
wait 5 sec
- Orange LAN light flashes quickly
Any clue on this Status lights Flashing sequence TS-451+
- OneCD
Re: Any clue on this Status lights Flashing sequence TS-451+
I suggest you create a support ticket with QNAP.
- storageman
Turn off and pull drives, do you get an IP address in Qfinder, reseat the drives and check access again.
For lights these are documentedhttp://docs.qnap.com/nas/4.1/Home/en/index.html?checking_system_status.htm
I Did created the ticket, They asked me to send the unit to them.OneCD wrote:I suggest you create a support ticket with QNAP.
Did this troubleshooting ... with and without drives as well the NAS is not booting up. removed the upgraded RAM as well, no luckstorageman wrote:Turn off and pull drives, do you get an IP address in Qfinder, reseat the drives and check access again.
- storageman
Sounds gone, before you give up try connecting direct to PC/laptop and make sure no antivirus is blocking Qnap Finder, or check for any unknown connected devices in switch/router.
I'm turning mine on for the first time since moving house and getting the same lights
Did they fix/replace it? Do you know what the problem was?
ETA: I wonder if I'm using the wrong power supply? Does anyone have a photo of the correct one please?
please do not necropost into 5 year old topics (even more so if there is plenty of current topics about this issue)
this should give you a hint
viewtopic.php?f=45&t=157459
topic > closed
topic > closed
