RAID 5 in degraded mode + WebUI not accessible
antimatter84
Post by antimatter84 »
here's what happened:
A "unrecovered read error" was detected.
Host: Drive1 Read I/O error, UNRECOVERED READ ERROR sense_key=0x3, asc=0x11, ascq=0x4, CDB=88 00 00 00 00 01 5c 41 33 18 00 00 00 08 00 00 .
The RAID is now in degraded mode.
Then a disk scan found 1 bad block. (This disk showed strange behaviour once before. It got suddenly recognized as "disconnected" for a few seconds, then "connected" again and started rebuilding. Then it worked. QNAP support could not find any problems.)
I decided to replace this disk and ordered a replacement disk. While waiting for it I shut down the NAS, for the time it being unattended.
Now I have the replacement hard drive and switched the NAS back on, the status LED goes red as expected, but now I cannot access the WebUI logon page. It only shows a blue background. Nothing else. Deleted firefox browser cache, tried 2 other browsers (IE, chromium). Does not help. Always the blue blackground.
SSH login works.
I don't know, what is happening with the Web UI and if I can safely continue replacing the disk in the current state. May be the RAID is in read-only mode because of the degraded state and therefore the web server won't work correctly, but frankly that's just guessing. Checking via SSH, a _thttpd_ and Qthttpd programs are running.
Helpful advice would be highly appreciated.
OS for NAS access: Windows 7
NAS Model: TS-431+
Firmware: 4.2.1 build 20160701 (IIRC; can't access Web UI for confirmation)
Network: single port
Drive config: RAID 5
Number: 4 drives
Drive manufacturer: Western Digital
Drive model: WD Red WD30EFRX 3 TB
dolbyman
Re: RAID 5 in degraded mode + WebUI not accessible
Post by dolbyman »
you should have never shut it down, just swapped the drive while running
login via SSH possible ?
if so do
cat /proc/mdstat
antimatter84
I already suspected, that shutting it down was not a good idea. I'll remember it next time. Here's the mdstat:
md256 : active raid1 sdd2[3](S) sdc2[2](S) sdb2[1] sda2[0]
      530112 blocks super 1.0 [2/2] [UU]
      bitmap: 0/1 pages [0KB], 65536KB chunk
md13 : active raid1 sda4[0] sdd4[3] sdc4[2] sdb4[1]
      458880 blocks super 1.0 [24/4] [UUUU____________________]
      bitmap: 1/1 pages [4KB], 65536KB chunk
md9 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1]
      530048 blocks super 1.0 [24/4] [UUUU____________________]
unused devices: <none>
dolbyman
Post by dolbyman »
looks like your data raid volume (should be md0 ?) did not mount
contact qnap via ticket, so they try to reassemble the RAID
antimatter84
Ok, will do that. Thank you.
dolbyman
Post by dolbyman »
can you do
cat /etc/config/mdadm.conf
antimatter84
No, there's only a symlink in "/etc": mdadm.conf -> config/mdadm.conf@
But the file it points to does not exist.
dolbyman
Post by dolbyman »
oh..hmm..ok
MrVideo
Experience counts
Post by MrVideo »
dolbyman wrote:you should have never shut it down, just swapped the drive while running
He didn't shut it down to swap out the drive, he shut it down waiting for the replacement drive to arrive and then turned it back on in order to replace the drive.
QTS MANUALS
Asking a question, include the following
(Thanks to Toxic17)
Entware
MrVideo
Experience counts
Post by MrVideo »
dolbyman wrote:can you do
Doesn't exist on either of my boxes either.
QTS MANUALS
(Thanks to Toxic17)
Entware
dolbyman
Post by dolbyman »
I found it in the forum, contained volume name, RAID type and devices involved, must be outdated
OneCD
Post by OneCD »
How about:
cat /mnt/HDA_ROOT/.conf
antimatter84
[/] # cat /mnt/HDA_ROOT/.conf
hw_addr=3E:14:18:93:39:67
QNAP=TRUE
mirror=0
hal_support=yes
sm_v2_support=yes
pd_dev_wwn_50014EE2629593AE=0x1
pd_dev_wwn_50014EE2B7E5B47C=0x2
pd_dev_wwn_50014EE2628EE173=0x3
pd_dev_wwn_50014EE26295B4D8=0x4
nas_capability=0x1
OneCD
Post by OneCD »
Sorry - I don't have a solution. Only suggested this file in case it was the one @dolbyman was looking for. ;)
