Mount SSD as SSD
- hakannordell
Mount SSD as SSD
Hello, I probably need some help here.
I bought a StarTech.com Dual-Bay 2.5 to 3.5in Adapter Enclosure with SATA III and RAID in order to put two solid-state drives in one bay.
One Samsung SSD 850 PRO 256GB disk, that is alone in the QNAP original bay without an adapter, shows up completely normal.
In contrast, the corresponding SSD in the dual bay in next QNAP slot, have a ID ASMT109x- RAID1 and it is mounted and displayed as HDD, and thus can not be used as SSD in Qutier for example.
What I want to do, is that the SSD in the dual bay will be discovered or installed as SSD.
Any suggestions?
Links to StarTech.com Dual-Bay 2.5 to 3.5in Adapter Enclosure with SATA III and RAID
https://www.proshop.se/Datalagring/Star ... ID/2569191
/Håkan
Any suggestions?
/Håkan
[Plex Runner] QNAP TVS-471 (QTS 4.3.4.0435), Intel Core i7-4790S, 16GB RAM, 768GB 850 Pro SSD for System and Transcoding, RAID-1, Shared APC 750
[Data Holder and Plex Runner] TS-1685 (QTS 4.3.4.0435), Qtier, 16GB RAM, 1,5TB 850 EVO M2, 512GB 850 Pro and 512GB EVO SSD, 32TB RED RAID-5,, Shared APC 750 and 10 GbE SFP+
[Master Backup] QNAP TS-1635 (QTS 4.3.4.0435), 16GB RAM, 512GB Pro SSD, 24TB RED RAID-5, Shared APC 750 and 10 GbE SFP+
[Seconary Backup] QNAP UX-500P, 20TB RED RAID-5, Shared APC 750
[Torrent Runner] QNAP TS-431 (QTS 4.3.4.0435), 0TB RED RAID-1, Shared APC 750
[Off-Site Backup] NetGear ReadyNAS Ultra 6 (ReadyNAS OS 6.7.5), Seagate 12TB RAID-0, Singel APC SC 620
[Other Cool Stuff] Linksys LRT224 DualWAN, Fibaro HC2
Re: Mount SSD as SSD
does not work that way, the drives are "combined" into a new device, be glad that the NAS recognizes it at all
- Don
Yeah, won't work. Suggest you open a ticket with QNAP for an enhancement request.
- Trexx
I would say while you might like the Startech to work that way for you, its probably not going to happen.
QNAP has enough challenges with all their certification work when dealing directly with the SSD drives. Having a 3rd party product between the QNAP and the SSD isn't something they are going to probably want to deal with.
SImple solution, remove the drive from the StarTech and mount in directly in the slot. I bet it shows up properly as an SSD.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
English description of device used
https://www.startech.com/HDD/Adapters/s ... 5SAT225S3R
Don't think contacting QNAP will do much , this is the posterchild example of and "unsupported usage"
- hakannordell
I already have an SSD in qnap slot 1, and it works well.Trexx wrote:SImple solution, remove the drive from the StarTech and mount in directly in the slot. I bet it shows up properly as an SSD.
It´s in dual bay in qnap slot 2 (and the SSD in that) tha´s receiving the ID ASMT109x- RAID1.
Must be a way to get around this
/H
The drives behind that controller are not transparent to the system, it presents a combined(RAID1) block storagehakannordell wrote: It´s in dual bay in qnap slot 2 (and the SSD in that) tha´s receiving the ID ASMT109x- RAID1.
If you create an ISCSI LUN on the NAs, there is no way for the OS that connects to that block storage to see what drive(s) this is actually sitting on
Extremely long shot, set the enclosure to JBOD instead of RAID1
- hakannordell
Here is fdisk -l
Device Boot Start End Blocks Id System
/dev/sdb1 1 243202 1953514583+ ee EFI GPT
Disk /dev/sdk: 256.0 GB, 256053870592 bytes
255 heads, 63 sectors/track, 31130 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/md1: 245.8 GB, 245861646336 bytes
2 heads, 4 sectors/track, 60024816 cylinders
Units = cylinders of 8 * 512 = 4096 bytes
Disk /dev/md1 doesn't contain a valid partition table
- hakannordell
But then I miss my purpose. To have RAID 1 on two disks on a disk location.dolbyman wrote:Extremely long shot, set the enclosure to JBOD instead of RAID1
You can't have two entities control the disks
Either the RAID controller in the adapter or the NAS, think about it
- hakannordell
That´s ok. I will only have the adapter RAID. But the problem is that qnap transform the SDD into HDD.dolbyman wrote:You can't have two entities control the disks
/H
- MrVideo
That is because the SSD is isolated from the NAS. If the SSD was directly connected to the NAS SATA, it would be seen as SSD. But, with the built in RAID chip, the whole device is presented to the NAS as a HDD. There is nothing you can do about that.
It is no different than the NAS being presented to computers as one massive hard drive. The computer has no clue as to what physical devices are actually storing the data.
QTS MANUALS
Entware
Entware
- hakannordell
Everyone says that it can´t be done, so I give up the idea now. Anyone want to buy a DualBay? I have now rebuilt the structure and put all the hard drives in the UX-500P. The 471 has now RAID-1 with system on the SSD. In the third bay I have the cache and in the fourth, I put a 2TB HDD, but do I really need that not be because the UX has 5 x 4TB on RAID-5. However, I discovered that it is not possible to deploy SSDs in UX. It does not recognize that there is a SSD in the bay.MrVideo wrote:It is no different than the NAS being presented to computers as one massive hard drive. The computer has no clue as to what physical devices are actually storing the data.
@All: Thanks for all help.
/Håkan
the expansion box is usb attached ....not much use for SSDs in there..you are a bundle of bad idras eh ? :p
@Håkan, It's too late for us to give advice now that you've already spent a lot of money on that system. The next time, please ask before buying and configuring.
