TS-439 Pro - Unknown login
I have unknown user login every time when reboot NAS.
See the below snap-shot and anyone can advise how to fix it? I have submitted the helpdisk ticket, but still work in progress without conclusion.
- OneCD
Re: TS-439 Pro - Unknown login
Is it cause CPU high-load of the process "vpnfilter"?
Almost consuming 50% of CPU resource
- OneCD
Uh-oh. Suggest you install and run the QNAP MalwareRemover immediately. It's available in the QNAP App Center.
Seems the 'vpnfilter' process has already been identified as malware.
I have installed QNAP MalwareRemover 2.1.2, then upgrade to 2.1.3 and I found the problem.
downgrade to 2.1.2 still have problems
- OneCD
when uninstall malware remover, CPU high load has disappear.
- Easy as a breeze
Managed to remove vpnfilter about a week or so ago only for it to re-appear this morning with malware remover installed and running a daily scan.
Eugh.
Eugh.
TVS-872XT-i5-16GB with 6*ST12000VNZ008 in RAID 6.
Backed up to a stack of a half dozen 'cold' external 12TB and 8TB HDDs - please back up your data, RAID is not the same as a backup!
Formerly TVS-463 with 4*WD60EFRX in RAID5, planning to reuse as an additional backup destination in the new year.
All protected by an APC SMT750VA UPS - protect your NAS from bad power!
- schumaku
Find the attached short term fix to remove the crap again.
Double check the code before running it please.
- Easy as a breeze
Okay, question:
Why kill qsync? Is this a qsync vulnerability?
I have it running but use it sufficiently rarely I should probably disable it.
I'm not an SSH wizard (hell two weeks ago I didn't even know how to log in!) so I would appreciate if you would explain the purpose of this line
before I run it.
sed -i '/qsync_init/d' /etc/config/crontab
- schumaku
I've never seen the infection live on a NAS - however, obviously it's hiding under a faux qsync.php - this is unrelated to the real Qsync code in place.
The sed will remove a questionable entry from the crontab.
#!/bin/sh
killall -9 qsync.php
killall -9 vpnfilter
rm -f /etc/config/qsync.php
rm -f /etc/config/qsync_init.sh
rm -rf /mnt/ext/opt/fsget
- Easy as a breeze
I killed vpnfilter earlier this week so there's no longer an active vpn process
Should I still run
or is that now unnecessary.
Edit: I ran the script and got the following output
What now?
[~] # ps - ef | grep vpnfilter
28381 admin 1032 S grep vpnfilter
[~] # #!/bin/sh
[~] # killall -9 qsync.php
killall: qsync.php: no process killed
[~] # killall -9 vpnfilter
killall: vpnfilter: no process killed
[~] # rm -f /etc/config/qsync.php
[~] # rm -f /etc/config/qsync_init.sh
[~] # rm -rf /mnt/ext/opt/fsget
[~] # sed -i '/qsync_init/d' /etc/config/crontab
after contacting QNAP I received this reply and it worked no more vpnfilter hogging my processor, I copied these commands obviously without the #
Dear Darren
Thanks for writing us.
Please follow my instructions,
1. Then login to NAS via SSH using putty (Please refer the attached document for how to do it?)
2. Then copy & paste the following commands and execute it one-by-one in the SSH,
Please execute the above commands and make sure the VPNFILTER process removed or not? Kindly confirm.
Thanks!
Best Regards
Arun
QNAP Systems Inc.,
Dear Darren
Thanks!
Best Regards
Arun
QNAP Systems Inc.,
Script cleared things right up. Very helpful. Thanks.
Great job people.
Just logged in to my qnap ts251 (which had the same issues) using putty and copied/pasted the code.
My CPU usage dropped from 100% to around 5% instantly.
fingers crossed it stays this way.
again, many thanks for the help
Jason
Jason
