How to use full capacity of disks?
I have read lots of info on forums and QNAP manuals, but I just don't get it. So looking for help.
TS-253A with QTS 4.3.3.0210
I have 2 WD Red 4TB HDD's in RAID 1 mirror config.
My DataVol1 shows capacity of 1.65TB and my storage pool 1 shows 3.63TB capacity.
The actual size of all files on disk is 935GB (55% used of 1.65TB).
The allocated volume for the storage pool is 3.28TB (85% of 3.63TB).
So how can I make full use of the +/- 4TB that should be available for storage? Should I expand the DataVol1 so it goes up to +/- 4TB? Should I then also do something at the storage pool level?
I understand the storage pool will never get higher than 4TB because I am essentially only utilizing a single disk, and the other disk is for replication only.
Thanks!
Thanks!
- Easy as a breeze
Re: How to use full capacity of disks?
Happy to!NAS_hans wrote:I have read lots of info on forums and QNAP manuals, but I just don't get it. So looking for help.
Okay couple of things here. I'm presuming you know how a 6TB drive isn't a 6TB drive. Basically, it's the difference between TiB and TB. I would suggest reading this wikipedia article https://en.wikipedia.org/wiki/Binary_pr ... _confusion if you don't. It may clear some things up for you! It's also explained better https://www.quora.com/What-is-the-diffe ... bibyte-TiB over at Quora.
What this means practically is that a 4TB drive has about 3.6TB of usable capacity.
In RAID 1, 1 disk is used for redundancy. This means that with a 3.63 storage pool capacity is normal. It will not go any higher than that. However your data volume capacity of 1.65TB is...odd. Did you recently move from 2TB to 4TB drives?
What is the size of your data volume? The 3.28TB size of your Storage Pool 1 divided by 2 = 1.64TB (which is close enough to 1.65TB). This makes me think you can expand your data volume if you want to as only 50% is being used. Can you log into your NAS, open "Storage Manager" (found under main menu). Then, in "Storage Manager", click on "Storage Space" under "Storage". Then, click the drop down arrow by the name of your storage pool to see the size of your data volume. It may look like this or a slight variation (better quality image here http://i.imgur.com/atcOKrv.jpg). Please screenshot this menu so we can try to work out if you can expand your data volume then post a new post.
FYI Expanding datavolume/storage volume capacity is not foolproof - people have lost data or even entire volumes in the past, so I strongly advise creating a backup if you haven't already done so.
TVS-872XT-i5-16GB with 6*ST12000VNZ008 in RAID 6.
Backed up to a stack of a half dozen 'cold' external 12TB and 8TB HDDs - please back up your data, RAID is not the same as a backup!
Formerly TVS-463 with 4*WD60EFRX in RAID5, planning to reuse as an additional backup destination in the new year.
All protected by an APC SMT750VA UPS - protect your NAS from bad power!
- MrVideo
When a new volume is created, only 50% of the available space is allocated. You must go set it to max.
QTS MANUALS
Entware
Entware
- Easy as a breeze
Huh. That I did not know. Im presuming that's because volumes can't be downsized post creation.MrVideo wrote:When a new volume is created, only 50% of the available space is allocated. You must go set it to max.
- MrVideo
I've never tried to find out why QNAP has done that. I just set it to max as soon as I can.
QTS MANUALS
Entware
Entware
Exactly!jacobite1 wrote:Huh. That I did not know. Im presuming that's because volumes can't be downsized post creation.MrVideo wrote:When a new volume is created, only 50% of the available space is allocated. You must go set it to max.
It's because disk capacity can for some users sometimes be better used for other things than as an half empty plain shared storage.MrVideo wrote:I've never tried to find out why QNAP has done that.
Snapshots (a revolution when introduced) and Block-based iSCSI LUNs (which by Qnap is recommended over file based LUNs) are the two things I come to think of immediately.
Which is an irreversible action so unless absolutely sure of that you never ever want to use any of the new features offered by LVM/Storage pools (two mentioned above) that's not a very smart thing to do until you really need to use more of that available storage capacity as shared storage.I just set it to max as soon as I can.
When a users have eventually learned about all the new possibilities offered by a modern NAS and realized they would want to use any of it, it would be a pity if they had already wasted all available storage on a maximum capacity shared volume not fully used.
That's the reason Qnap doesn't allocate all available storage to a single volume to start with. It's a actually a very nice thing they do for the newbies that have not yet understood everything about their new NAS.
- MrVideo
Nope, will never use snapshots or LUNs, or anything else, but storage. My TS-869L is almost full as it is.P3R wrote:jacobite1 wrote:Which is an irreversible action so unless absolutely sure of that you never ever want to use any of the new features offered by LVM/Storage pools (two mentioned above) that's not a very smart thing to do until you really need to use more of that available storage capacity as shared storage.
QTS MANUALS
Entware
Entware
Thanks all for your input, this certainly explains the things I am seeing. So I will simply do the "expand volume" (I will only use my NAS for storage, no snapshots etc but thanks for the clear explanation).
- Easy as a breeze
Ensure you have a backup (or 2, or 3) before you start.NAS_hans wrote:Thanks all for your input, this certainly explains the things I am seeing. So I will simply do the "expand volume" (I will only use my NAS for storage, no snapshots etc but thanks for the clear explanation).
The expansion process is not 100% foolproof. Your NAS may crash and you may loose data or suffer a write hole.
Alright, I've done the expand volume, but I've had to do it in small increments, because the "Set to Max" button only increased slightly after each expand volume:
From 1.65TB to 2.02TB to 2.36 to 2.71 to 3.06
Is that normal behaviour?
I am having the same issue. 2x3Tb hard drives, just 1Tb of storage space. I really, really, really, don't care about SCSI; this is just something for me that got replaced by SATA, it should not exist anymore, and cannot justify using half a drive space. Snapshots make no sense to me in that context. The idea of the NAS is to implement RAID, which can already replicate the drives. The NAS should not halve the drive's capacity for something that is not related to RAID and backups. I cannot figure out how to set disk size to max. That should have been done automatically, it makes no sense to keep half the drives unallocated. This is a major con, not mentioned in any review of the QNAP devices.
you are mixing up iscsi and scsi .. has nothing to do with sata vs scsi
2nd post explains how to expand the volume to more than 50%
It's very helpful to all other newbie users that doesn't understand that they need to reserve space initially on installation if they ever later realize they wanted to use snapshots, iSCSI (block-based) or multiple volumes.EricBuist wrote:That should have been done automatically, it makes no sense to keep half the drives unallocated.
As it's always possible to expand (but not shrink) a volume, you can now easily do that but all other users with different expectations would be stuck if Qnap had defaulted to what you wish.
Thanks. I figured out how to expand the volume size. I still don't understand why iSCSI and snapshots would require unallocated space to work, though.
Because they're not stored inside the main storage volume but beside it. If the main storage volume automatically take up all usable capacity, like you suggested, there's no storage capacity left to use for the features I mentioned.EricBuist wrote:I still don't understand why iSCSI and snapshots would require unallocated space to work, though.
LVM (storage pools) added another layer above the RAID that removed previous migration/expansion capacity limitations, added several new features and increased flexibility of the storage. But yes, that at the same time meant that us used only to basic Linux md RAID had to learn some new things to understand how it works.
Once I had learned the basic differences, I found the following graphic from the Qnap documentation very helpful to understand how things are related to each other:
