Unable to mount or recover Volume after power lost.
Hi all,
this morning after a power lost, my TS453A with firmware 4.2.4, start to fail. The main volume, Volume 1, was unmounted and when I try
to check it, I get an error "pool 1 Error examinning VOL 1" at 1% (after 10´15 secs).
I've openned a ticked but I really need to recover and mount de raid volume as soon as possible.
Can someone help me ?
Thanks.
Thanks.
Re: Unable to mount or recover Volume after power lost.
SSH in and check
cat /proc/mdstat
and get in the process of getting a UPS asap (and doing backups!)
cat /proc/mdstat
Could yo give me the steps to solve it ?. More detailed please.dolbyman wrote:SSH in and check
cat /proc/mdstat
If I lose the volume my wife will kill me for sure.
Thanks.
- Easy as a breeze
What operating system do you use?
TVS-872XT-i5-16GB with 6*ST12000VNZ008 in RAID 6.
Backed up to a stack of a half dozen 'cold' external 12TB and 8TB HDDs - please back up your data, RAID is not the same as a backup!
Formerly TVS-463 with 4*WD60EFRX in RAID5, planning to reuse as an additional backup destination in the new year.
All protected by an APC SMT750VA UPS - protect your NAS from bad power!
I'm using Windows 10jacobite1 wrote:What operating system do you use?
- Easy as a breeze
Okay I'll walk you through the first bit.jdgszorro wrote:I'm using Windows 10jacobite1 wrote:What operating system do you use?
If you use Windows, you'll need to download Putty http://www.putty.org/
Once you've got Putty open let me know, my windows10 machine is being super slow.
I can access trought ssh. I've already used before.jacobite1 wrote:Okay I'll walk you through the first bit.jdgszorro wrote:I'm using Windows 10jacobite1 wrote:What operating system do you use?
I'm readyjdgszorro wrote:I can access trought ssh. I've already used before.jacobite1 wrote:Okay I'll walk you through the first bit.jdgszorro wrote:I'm using Windows 10jacobite1 wrote:What operating system do you use?
- Easy as a breeze
Okay then type in/copy
into the ssh command line and hit enter - this will tell you the status of your array and give you an output, please post it here in the code wrapper like this:
That's mine, and it's a healthy array.
cat /proc/mdstat
md1 : active raid5 sda3[0] sdc3[2] sdd3[3] sdb3[1]
17551702848 blocks super 1.0 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md256 : active raid1 sdd2[3](S) sdc2[2](S) sdb2[1] sda2[0]
530112 blocks super 1.0 [2/2] [UU]
bitmap: 0/1 pages [0KB], 65536KB chunk
md13 : active raid1 sda4[0] sdd4[25] sdc4[24] sdb4[1]
458880 blocks super 1.0 [24/4] [UUUU____________________]
bitmap: 1/1 pages [4KB], 65536KB chunk
md9 : active raid1 sda1[0] sdd1[25] sdc1[24] sdb1[1]
530048 blocks super 1.0 [24/4] [UUUU____________________]
unused devices: <none>
md2 : active raid1 sdd3[0]
7804071616 blocks super 1.0 [1/1]
md1 : active raid5 sda3[0] sdc3[2] sdb3[1]
11701135232 blocks super 1.0 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
bitmap: 0/44 pages [0KB], 65536KB chunk
I've 3x6TB WD RED in RAID 5 (Volume 1 -- Problem) and 10TB Seagate in a Raid 1 (Volume 2--- Working).
- Easy as a breeze
Okay I'm a little confused so I'm going to do some reading up for you now - you've got [3/3] [UUU] which means 3 healthy drives in your r5 array. Hopefully someone more capable than me like dolbyman can help whilst I'm reading about MDADM (qnap raid)
(dolbyman I've quoted you just to make sure you see OP's cat /proc/mdstat output, sorry!)
EDIT: Op in the meantime please run the following Hard drive smart test by copying the following code:
and change 1 to 2 and 3 like this
cat /proc/mdstat
getsysinfo hdsmart 1
[~] # getsysinfo hdsmart 1
GOOD[~] #
[~] # getsysinfo hdsmart 2
GOOD[~] #
[~] # getsysinfo hdsmart 3
GOOD[~] #
[~] # getsysinfo hdsmart 4
GOOD[~] #
OK. Thanks
The problem is that md1 is unmounted and when I try to check the system file integrity from web storage manager. I get an error. Pool 1 error checking and can't mount.
Done.... waitting to finish.jacobite1 wrote:Okay I'm a little confused so I'm going to do some reading up for you now - you've got [3/3] [UUU] which means 3 healthy drives in your r5 array. Hopefully someone more capable than me like dolbyman can help whilst I'm reading about MDADM (qnap raid)
cat /proc/mdstat
and change 1 to 2 and 3 like thisCode: Select all
[~] # getsysinfo hdsmart 1 GOOD[~] # [~] # getsysinfo hdsmart 2 GOOD[~] # [~] # getsysinfo hdsmart 3 GOOD[~] # [~] # getsysinfo hdsmart 4 GOOD[~] #
- Easy as a breeze
jdgszorro wrote: Done.... waitting to finish.
Waitwaitwait don't copy the second box of code, just the first. Increment the number each time it performs and output.
Also I don't know why it won't mount. You can manually unmount and mount a RAID array using SSH but you really don't have to have to do that.
GOOD[~] # getsysinfo hdsmart 2
GOOD[~] # getsysinfo hdsmart 3
GOOD[~] # getsysinfo hdsmart 1
But may be the solution is to use "e2fsck" to force the validation ?
e2fsck -f /dev/md1
I've seem it in a previous post. But ..... I'm not sure and I don't want to lose the data.
e2fsck -f /dev/md1
