Hey folks,
I have a TS-451a with four 3TB Western Digital "Red" drives in it. Firmware version is 4.3.3.0262.
Until today it's been great, but this afternoon someone (possibly me ) accidentally interrupted its power supply. When I plugged it back in, the RAID volume was down because disks 3 & 4 didn't exist, according to Storage Manager. Obviously nothing had changed with the physical mounting of the disks, and there was no serious jostling, but I went through several shutdown, unplug, replug, restart cycles, to no avail.
Finally I logged in over ssh and tried to rescan the SCSI bus, fdisk -l, etc., no dice. I looked at dmesg and there were a couple boot messages like "md: kicking non-fresh sdc3 from array". I tried to mdadm --fail, --remove, --add, etc. and it complained that /dev/sdc3 didn't exist--sure enough the device nodes for /dev/sdc, /dev/sdd, /dev/sdc* and /dev/sdd* were missing! I recreated them with mknod, rebooted one more time, and it looks like it worked.
Now, the complaint! this is a pretty common failure mode, and the system software really should be able to deal with it better. 99.5% of the population are unable and/or unwilling to go the lengths I went to to restore service.
Thanks!
TS-451a: power interruption caused two disks to go offline, I fixed it but shouldn't have had to :)
- Don
Re: TS-451a: power interruption caused two disks to go offline, I fixed it but shouldn't have had to :)
Sudden power loss on a NAS can cause all kinds of issues. The solution is to purchase a UPS that will gracefully shut the NAS down when there is a loss of power.
Well beyond saying that, is there anything to do? I do not know enough UNIX to follow the fix.
BTW: I do have a UPS, it failed.
- OneCD
