I encounter a very nasty error - system volume is full - even if I use no more than 200Gb from 2.6Tb with my personal data.
It looks like my system files are 'growing' day by day but I was not able to identify the reason.
Had a look on this forum, a lot of similar topics but different root causes, so I'm attaching few data from my ssh session. Maybe some of you experienced similar situation or have a better understanding of the topic than me.
Please be aware that I disabled and empty the Network Recycle bin already.
Thank you in advance for your availability for my troubleshooting.
Br,
Catalin
[/share/snapshot/export] # echo "NAS Model: $(getsysinfo model)"
NAS Model: TS-453A
[/share/snapshot/export] # echo "Firmware: $(getcfg system version)"
Firmware: 4.3.3
[/share/snapshot/export] # cat /proc/mdstat
md3 : active raid1 sdd3[0]
2920311616 blocks super 1.0 [1/1] [U]
md2 : active raid1 sda3[0] sdb3[1]
2920311616 blocks super 1.0 [2/2] [UU]
md1 : active raid1 sdc3[0]
md256 : active raid1 sdd2[3](S) sdc2[2](S) sdb2[1] sda2[0]
530112 blocks super 1.0 [2/2] [UU]
bitmap: 0/1 pages [0KB], 65536KB chunk
md13 : active raid1 sda4[0] sdd4[25] sdb4[24] sdc4[1]
458880 blocks super 1.0 [24/4] [UUUU____________________]
bitmap: 1/1 pages [4KB], 65536KB chunk
md9 : active raid1 sda1[0] sdd1[25] sdb1[24] sdc1[1]
530048 blocks super 1.0 [24/4] [UUUU____________________]
unused devices: <none>
[/share/snapshot/export] # df -h
Filesystem Size Used Available Use% Mounted on
none 250.0M 193.6M 56.4M 77% /
devtmpfs 7.8G 8.0K 7.8G 0% /dev
tmpfs 64.0M 960.0K 63.1M 1% /tmp
tmpfs 7.8G 56.0K 7.8G 0% /dev/shm
tmpfs 16.0M 0 16.0M 0% /share
tmpfs 16.0M 0 16.0M 0% /share/snapshot/export
/dev/md9 493.5M 140.5M 352.9M 28% /mnt/HDA_ROOT
cgroup_root 7.8G 0 7.8G 0% /sys/fs/cgroup
/dev/mapper/cachedev1
2.6T 2.6T 23.2G 99% /share/CACHEDEV1_DATA
/dev/mapper/cachedev2
2.6T 979.8G 1.7T 36% /share/CACHEDEV2_DATA
/dev/mapper/cachedev3
2.5T 1.8T 655.6G 74% /share/CACHEDEV3_DATA
/dev/md13 355.0M 343.7M 11.3M 97% /mnt/ext
CloudDrive 2.0M 2.0M 1.0M 67% /mnt/rf/cd
tmpfs 16.0M 144.0K 15.9M 1% /share/CACHEDEV1_DATA/.samba/lock/msg.lock
tmpfs 16.0M 0 16.0M 0% /mnt/ext/opt/samba/private/msg.sock
tmpfs 1.0M 0 1.0M 0% /mnt/rf/nd
tmpfs 64.0M 960.0K 63.1M 1% /share/CACHEDEV1_DATA/.qpkg/HD_Station/tmp
/dev/md9 493.5M 140.5M 352.9M 28% /share/CACHEDEV1_DATA/.qpkg/HD_Station/etc/config
none 250.0M 193.6M 56.4M 77% /share/CACHEDEV1_DATA/.qpkg/HD_Station/home/httpd/RSS/images
none 250.0M 193.6M 56.4M 77% /share/CACHEDEV1_DATA/.qpkg/HD_Station/etc/init.d
none 250.0M 193.6M 56.4M 77% /share/CACHEDEV1_DATA/.qpkg/HD_Station/etc/rcS.d
none 250.0M 193.6M 56.4M 77% /share/CACHEDEV1_DATA/.qpkg/HD_Station/etc/rcK.d
none 250.0M 193.6M 56.4M 77% /share/CACHEDEV1_DATA/.qpkg/HD_Station/etc/default_config
none 250.0M 193.6M 56.4M 77% /share/CACHEDEV1_DATA/.qpkg/HD_Station/etc/platform.conf
none 250.0M 193.6M 56.4M 77% /share/CACHEDEV1_DATA/.qpkg/HD_Station/etc/hal_util.conf
2.6T 2.6T 23.2G 99% /share/CACHEDEV1_DATA/.qpkg/HD_Station/share/CACHEDEV1_DATA
2.6T 979.8G 1.7T 36% /share/CACHEDEV1_DATA/.qpkg/HD_Station/share/CACHEDEV2_DATA
2.5T 1.8T 655.6G 74% /share/CACHEDEV1_DATA/.qpkg/HD_Station/share/CACHEDEV3_DATA
none 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/HD_Station/sys/fs/cgroup
udev 7.8G 8.0K 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/HD_Station/dev
tmpfs 7.8G 864.0K 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/HD_Station/run
none 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/HD_Station/run/shm
none 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/HD_Station/run/lock
none 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/HD_Station/run/user
2.6T 2.6T 23.2G 99% /lib/modules/4.2.8/container-station
2.6T 2.6T 23.2G 99% /share/CACHEDEV1_DATA/.qpkg/container-station/system-docker/devicemapper
/dev/mapper/docker-252:0-121904489-095750efd26ee286afef59afd6673141fc57c56c9a42f51285bef58a6a6a2b28
9.8G 653.3M 8.7G 7% /share/CACHEDEV1_DATA/.qpkg/container-station/system-docker/devicemapper/mnt/095750efd26ee286afef59afd6673141fc57c56c9a42f51285bef58a6a6a2b28
shm 64.0M 0 64.0M 0% /share/CACHEDEV1_DATA/.qpkg/container-station/system-docker/containers/5067368d8ea76b06fbd0fff715e6dc23e8c983447ae2ce4a686c74d3041db54e/shm
[/share/snapshot/export] # ls -alFh /share/CACHEDEV1_DATA
total 216
drwxrwxrwx 42 admin administ 4.0K Aug 18 21:06 ./
drwxrwxrwt 34 admin administ 920 Aug 18 21:06 ../
drwxr-xr-x 2 admin administ 4.0K Aug 21 08:04 .@analytic/
drwxr-xr-x 2 admin administ 4.0K Aug 16 03:04 .@backup_config/
drwxr-xr-x 2 admin administ 4.0K Aug 16 03:04 .@backup_qbox/
drwxr-xr-x 2 admin administ 4.0K Aug 18 18:22 .@backup_qfiling/
drwxr-xr-x 4 admin administ 4.0K May 22 2016 .@qmariadb/
drwx------ 4 admin administ 4.0K Aug 18 18:21 .@qmonitor/
drwx------ 4 admin administ 4.0K Aug 19 07:02 .@qsync/
drwxr-xr-x 9 admin administ 4.0K Feb 28 22:12 .@twonkymedia.db/
drwxr-xr-x 3 admin administ 4.0K May 23 2016 .QKVM/
drwxr-xr-x 6 admin administ 4.0K May 24 2016 .antivirus/
drwxr-xr-x 3 admin administ 4.0K May 22 2016 .appDB/
drwxr-xr-x 2 admin administ 4.0K May 22 2016 .idmap/
drwxr-xr-x 2 admin administ 4.0K May 22 2016 .ldapdb/
drwxr-xr-x 2 admin administ 4.0K Aug 18 18:11 .locks/
drwxr-xr-x 2 admin administ 4.0K May 21 2016 .log/
drwxrwxrwx 2 admin administ 4.0K Feb 28 23:15 .magick_tmp/
drwxr-xr-x 3 admin administ 4.0K May 23 2016 .nvr/
drwxrwxrwx 2 admin administ 4.0K Aug 18 18:20 .php_session/
drwxr-xr-x 4 admin administ 4.0K Aug 18 21:08 .php_session_sys/
drwxr-xr-x 3 admin administ 4.0K Jun 7 22:14 .qbox/
drwxrwxrwx 88 admin administ 4.0K Aug 18 18:54 .qpkg/
drwxr-xr-x 6 admin administ 4.0K Aug 18 18:11 .samba/
drwxrwxrwx 5 admin administ 4.0K Aug 18 18:11 .spool/
d--------- 2 admin administ 4.0K Aug 13 17:19 .swap/
drwxr-xr-x 10 admin administ 4.0K Aug 18 18:13 .system/
drwxrwxrwx 3 admin administ 4.0K Feb 28 22:53 .team_folder/
drwxrwxrwx 2 admin administ 4.0K Feb 28 23:17 .tmp/
drwxr-xr-x 3 admin administ 4.0K Aug 18 18:13 .torrent/
drwxrwxrwx 2 admin administ 4.0K May 21 2016 .versioning/
drwxrwxrwx 5 admin administ 4.0K Aug 19 07:04 Back-up/
drwxrwxrwx 2 admin administ 4.0K Aug 16 20:11 Download/
drwxrwxrwx 3 admin administ 4.0K Aug 16 20:11 Multimedia/
drwxrwxrwx 2 admin administ 4.0K May 21 2016 OceanKTV/
drwxrwxrwx 4 admin administ 4.0K Aug 16 20:11 Public/
drwxrwxrwx 2 admin administ 4.0K Nov 28 2016 QmailAgent/
drwxrwxrwx 3 admin administ 4.0K Aug 16 20:11 Recordings/
drwxrwxrwx 4 admin administ 4.0K Aug 16 20:11 WM_W7/
drwxrwxrwx 2 admin administ 4.0K Aug 18 21:19 Web/
-rw------- 1 admin administ 9.0K May 26 18:21 aquota.user
drwxrwxrwx 7 admin administ 4.0K Aug 16 20:11 homes/
drwx------ 2 admin administ 16.0K May 22 2016 lost+found/
lrwxrwxrwx 1 admin administ 9 May 23 2016 optware -> /dev/null
