I used "safe detach" feature in my TS-453Bmini to take HDD out of NAS (it was set up as a single volume). Then I inserted it into HDD doc-station to attach it to the NAS as an external disk. I was surprised that the NAS can not see the files from this HDD.
How can I re-add it to the NAS without losing my data?
How re-add the drive which was "safely detached"
Re: How re-add the drive which was "safely detached"
Why on earth did you do that?EshkinCat wrote:I used "safe detach" feature in my TS-453Bmini to take HDD out of NAS (it was set up as a single volume). Then I inserted it into HDD doc-station to attach it to the NAS as an external disk.
If you had searched the forum you wouldn't have been surprised.I was surprised that the NAS can not see the files from this HDD.
Have you tried reinserting it?How can I re-add it to the NAS without losing my data?
I inserted it back but I can not see this single volume with files (screenshot is attached)
This HDD is shown as "free"
Please contact Qnap support and see if they manage to get it recognized again.
- Easy as a breeze
You can try which is about a 50/50 chance of bringing it back, and it will not delete any data on your disks.
/etc/init.d/init_lvm.sh
Model: TVS-872XT 16GB
Model: TS-877-1700 16GB
Support replied that after connecting HDD via USB, NAS no longer recognizes HDD.
That is really fantastic! NAS can not read his own disks via USB and makes them unusable. Now I have to use R-Studio to recover my data.
What you did isn't documented as a valid procedure so unexpected results are to be expected. When doing things out of the ordinary it's better to ask before doing it.
A NAS isn't a standard Linux computer so previous experience may not always be applicable.
Backup copies of all important data on a separate system is always strongly recommended with any data storage, especially when doing experimental stuff like this.
- Easy as a breeze
I put in a secondary drive into bay 5 of my 5 bay NAS and was running a backup script to it. I found out later that when ejecting out, and later inserting the drive back in, it cannot read it to save its' a$$!! So moral of the story is, any true backup must NOT be associated with anything QNAP or NAS! Rsync to a totally different machine as QNAP will screw ya. Yeah, you would think dropping a drive into another bay and backing up would work, but it doesn't!!
This thread is very sad but still a good reminder to everyone else that using internal disks as backup is for several reasons a bad idea. It may in some cases work but it's still a bad idea.
The moral of the story:
- A NAS isn't a simple file enclosure where disks should be swapped out and in (and if they are anyway, it's very risky using the disks elsewhere in the mean time)
- Backups are best done to disks connected externally with USB or over the network
- It's a good idea to search this forum and learn about best practice before doing things out of the ordinary
- A NAS isn't a standard computer so previous experience may not always be directly applicable
