My current setup 2x2tb in raid 0 (Hitachi Ultrastar's 7K3000 64mb/7200) is ready to be blowed up ;-( Disk 1 has a bad block so it's back 0 and re-deciding if my (as usual) questionable decision making (performance over safety Always) is worth it. I raid 0 I'm getting respectable perf. nothing earth shattering but faster than a pokey old locaL 1.5TB Barracuda Green (ST1500DL003 5900RPM SATA 6Gb/s 64MB) can'i complain. But now that I'm starting over was wondering what the risk reward was on the various setups, and while qnap gives a butlaod of perf. charts the qnap 212+ 1gb in Raid 0/1/JBOD/Single Vol does mot seem to be one of them,,
Qnap 90/55 vs the
Old notness 65/75 vs my system drive
The new hotness 800/800
Now that's a drive! (visiontek 240gb pci-e ssd)
Qnap 212+ Benchmarks Raid 0/1/JBOD/Single Vol?
- storageman
Re: Qnap 212+ Benchmarks Raid 0/1/JBOD/Single Vol?
Bear in mind a c: drive test is not a network test so pretty meaningless in the NAS world when a 1GbE port limits you.
Still SSDs are the future.
Trying to decide between raid 0 and individual volumes, data safety is not an issue but convenience is and replacing a drive in raid 0 is NOT convenient.. My main thing is seq. write raid 0 vs ind. volumes??
Read is bumping the the 1gbs but there is 50gb left on the write side, since the future is now is 100mbs write on the 212+ just a matter of loading it with fast enough ssd's?storageman wrote:Still SSDs are the future.
putting SSDs is an old ARM unit seems a waste of money
I doubt it can saturate the 1GbE with regular drives (no matter what disk/RAID config)
I was thinking sshd "firecuda" drives can be had for $50/$80 1tb/2tb which is pretty competitive the ulttrastar's I usually go with.. And with the aveage user getting + %44 bump $100 for a 2tb r0 with 340mbs write potential, well it sounds fun, where da 10gbs nas's at??
http://hdd.userbenchmark.com/Compare/Se ... 03vsm10357
Time to upgrade anyway, this seems like a screaming deal, 4tb 10GbE $374 from amz warehouse, with $140ishiun drives alone..dolbyman wrote:putting SSDs is an old ARM unit seems a waste of money
BUFFALO TeraStation 4 TB (2x2 TB) RAID NAS & iSCSI Desktop Storage
https://www.amazon.com/dp/B01N7N3YRI/ref=olcoimes _product_details?_encoding=UTF8&me=]
It's time to step to a 4-bay then. RAID 5 give better performance than a 2-bay RAID 0 AND the reliability and convenience of a redundant disk configuration.scottfree1 wrote:Trying to decide between raid 0 and individual volumes, data safety is not an issue but convenience is and replacing a drive in raid 0 is NOT convenient..
Desktop disks are not recommended for NAS use, neither by disk manufacturers nor by Qnap.I was thinking sshd "firecuda" drives...
It's here (SFP+ so would depend on what you intend to connect it to), choosing only one from the 44 Qnap models with 10 GbE built in that I've found. I didn't bother to count those with optional 10 GbE but there could be even more of them....where da 10gbs nas's at??
