Hi guys,
My faithful TS-659 Pro has been serving me well for something like 6 or 7 years. It's currently filled with 1.5TB Samsung Green drives. Yesterday, drive 3 finally failed, after giving me SMART alerts a couple of months ago. So I've pulled the trigger and purchased 6 new 4TB Seagate Ironwolf NAS drives - ST4000VN008.
I know that an online RAID expansion is out of the question as it's limited to 16TB volumes, and I'll be up around the 20TB mark with RAID-5 on this NAS. I've got enough storage to backup everything in my existing ~7TB NAS to external drives, but I want to keep everything the same - I don't want to reinstall apps, reconfigure Plex (and rebuild my library etc). I know that QNAP has a method for transferring NAS -> NAS and for expanding an existing NAS, but is there a valid way for me to essentially backup my entire NAS and move it to some external storage, then 'restore' that backup onto a fresh set of disks in the same NAS?
Really appreciate any advice you can give me. NAS is currently powered off and I'm awaiting delivery of the new drives.
Thanks very much, Phil
Replacing all drives in TS-659 Pro
- Don
Re: Replacing all drives in TS-659 Pro
Need to start over from scratch.
