HI all, my once-quiet TVS-871 now has disks chuntering away 100% of the time. After much searching for answers, or for methods of investigating what's going on, I installed an app called IOtop. The only disk access it shows is these; sometimes two lines, sometimes three lines; see https://imgur.com/a/WlrTh
I know virtually nothing about Linux. Can anyone suggest why these processes would be accessing my disks 100% of the time?
The only observation I can make is that an extra copy of this process is added if I manually play a video or song from the NAS on my Windows PC. I have a drive mapped in Windows Explorer, although I only use that mapped drive at night for file copies.
This happens even if I go to AppCenter and stop every app, although the only apps I have installed are Plex and Emby; see https://imgur.com/a/MFRks
(I tried submitting images with the [img] tag but I kept getting the error message "It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct.")
Constant disk access by /usr/local/samba/sbin/smbd?
- OneCD
Re: Constant disk access by /usr/local/samba/sbin/smbd?
Hi and welcome to the forum.
I don't have an answer for your first problem, but with regard to Imgur, ensure you "Copy" the address for "Direct Link", then surround it with therpg1966 wrote:(I tried submitting images with the
Thanks OneCD; I tried that, and the error resolved to "Your images may only be up to 1024 pixels wide". But at least I know for next time!
- OneCD
A way around that is to use one of the thumbnail sizes instead. I posted your image as a "huge thumbnail".
any strange processes running via "top"
No, nothing at all on "top" that's > 0% apart from the IOtop process and usr/local/samba/sbin/smbd.
But I've noticed that as soon as I disconnect the drive mapping from WIndows, the disk access stops. Maybe it's something like Windows trying to index the drive - but I don't have that mapped drive selected in the WIndows indexing tool.
- OneCD
Good question. I'm not sure how to disable Defender to check that out, but I'll get looking.
