I have a TS-431 running QTS 4.3.3 (SMB) and I currently have two 5 TB disks in a RAID1 configuration. I would like to upgrade to RAID5 by adding two 6 TB disks (which will be limited to 5 TB, but the 5 TB ones are impossible to find around here so I'm fine with it), but I'd like some clarification about whether it's indeed possible to do so without starting from scratch. I've read through the forums and I've read conflicting reports, such as online migration not being possible with SMB firmwares.
Page 90 of the latest 4.3.x SMB manual seems to say it is possible to migrate, but I'm not entirely sure whether this means the data will be retained:
Do steps 4 and 5 refer to the new disks only?1. Go to "Storage Manager" > "STORAGE" > "Storage Space".
2. Double click a storage pool to bring up the Storage Pool Management page.
3. Select a RAID group and click "Manage" > "Migrate".
4. Select the hard disk drive(s) from the list and click "Apply".
5. Please note that all data on the selected hard disk drive(s) will be erased. Click "Yes" if you are certain about this.
6. The chosen RAID configuration is migrated to the new one.
Otherwise, I suppose I can do it from scratch by using one of the new disks as a temporary buffer, like this:
1. Let A and B be the current disks in RAID1, and C and D be the new disks
2. Connect D via USB 3 to the TS-431 and format it
3. Copy all the data from the RAID1 volume to D using the File Station
4. Mount C into the TS-431, destroy the A+B RAID1 array and recreate a new RAID5 array using A+B+C
5. Copy everything back from D to the new RAID5 array
6. Mount D into the TS-431 and expand the array to include it as well.
Can anyone please confirm that that's an acceptable approach? I've never carried out this sort of operation on a NAS and I actually just suffered a catastrophic damage on a separate, non-NAS disk so I'm genuinely tentative about anything involving temporary loss of redundancy.
Thank you very much in advance.
