it looks like that I did a big mistake. I have a QNAP TS-228 and cannot connect anymore to it. I've applied two my second disk
dd if=/dev/urandom of=/dev/sdb bs=1024k count=1
After removing the second disk and booting my NAS nothing works anymore. I cannot access any folder or the QTS/Webgui. Chrome Console throws "ReferenceError: QTS is not defined". But I still can ping it. When I try to connect via ssh it asks for a password but does not accept my password anymore and also not the initial password. It looks like that erasing disk 2 affected as well disk1 or at least the config.
Is there anything I can do to get my qnap back to live without loosing my data?
I can reach the Smart Installation Wizard but I believe that following the wizard will delete anything on disk1.
Any hint would be helpful.
Thank you and kind regards
Felix
