unnecessary rebuld , why?
- OneCD
Re: Automatic rebuld ?
If you enable RAID bitmap before pulling the drive, then a rebuild won't be needed when it's reinserted.
- MrVideo
Re: unnecessary rebuld , why?
It is standard practice to do a rebuild when a drive is pulled and put back in. If any data is written to the RAID while the drive is pulled, it is therefore out-of-sync. Even RAID cards for PeeCees did a rebuild if a drive was pulled. Think about how RAID works and you'll understand why. Nothing to complain about.
QTS MANUALS
Entware
Entware
- MrVideo
That might work. But, as I wrote, new data to the RAID will cause the pulled drive to be out-of-sync.OneCD wrote:If you enable RAID bitmap before pulling the drive, then a rebuild won't be needed when it's reinserted.
QTS MANUALS
Entware
Entware
- OneCD
QNAP wrote:If the RAID group has a bitmap, only changes that were made after the disk was removed need to be synchronized, greatly speeding up the process.
- MrVideo
A sync needs to be done, none-the-less. Shorter the better though.OneCD wrote:QNAP wrote:If the RAID group has a bitmap, only changes that were made after the disk was removed need to be synchronized, greatly speeding up the process.
QTS MANUALS
Entware
Entware
